Fit and Finish Issues
Ric
Ric
San Bernardino, CA
Honda Accord
I just noticed driver side of my hood has a slight overlap that wasn't there earlier or at least I didn't see it. Could be from opening and slamming the door shut. So along with the tailgate with a bigger gap on the passenger side, the hood is a problem.
I'll have the dealer serviceddepartment look at my next service.
It is fixable.
joeb427
It is fixable.
My issue isn't quite as bad but it's there and I guess they'll send it to a body shop to do the repair if they can't . Yours came out great which is nice to know.
DBRanger
Springfield, Ohio
2019 Ford Ranger STX 4X4 2007 BMW 328i
A good reason to buy from dealer stock. most dealers won't put it on the lot like that. Of course I realize it's not always possible.
DakotaGuy
Black Hills, SD
2022 Ranger SuperCrew XLT Tremor
I waxed my Ranger today and it was the first time I really “went over” the paint job closely. Everything looked pretty good except a few spots on the roof where it looks like something was stuck to the sheet metal and they painted over it. Very small defects, but I noticed it when I was buffing it out. It’s a lease and it’s on the roof where you can’t see it, but for a 2019 $40k vehicle I think a person should expect a flawless paint job. If you had body work done at the body shop and they painted over a few tiny flakes of something a customer would and should complain.
Hi Folks,
After seeing results of these tweaks to the front fenders, I decided to see if I could improve the fit of the hood. Much to my amazement the tweak of about 1/8" on the left and a 1/16" produced a flush to fender for the edge of the hood... My concern about fitment around the headlight was a non issue. Happy camper... photograph might not show the improvement but I am pleased with the fine tuning for hood fitment.
Michigan Truck Plant needs to raise the chinning bar a bit...They need to adjust their fixtures under the No Adjust Build process..can't believe their audit process has not led to refinement of the hood fit.
Ford Motor Co. Reiterd.
toddiscdn
Todd
Blue Point, Ontario, Canada
2019 Ranger Lariat 4X4
I just did this today too Phil, mine wasn't too bad, but better now. Looks like bare metal under the fender bolts so I threw some primer on it before rust sets in, paint later
Reactions: Ric
Hey....No worries...fenders and hood are aluminum.... No rust...Aluminum oxide, yes...no rust...
best,
Hounddog409
Tod
Ohio
F150
Dont wait. Primer attracts moisture. But since they are aluminum.....not really needed.
Floyd
illinois
I noticed that mySuperCab ebony cloth rear seat does not have the light gray stitch accent like the front seat.
Is this true on the SuperCrew? how about on the XLT either cab?
I think it would get more visibility and better responses as a new thread...JMO..
best,
Ford Motor Co, Retired
Mustang2Ranger
Garrett
Southern California
My buddy who can fix anything could not live with my hood being off. He popped the hood and repositioned the fenders. They had to be pulled out 1/4 on the driver’s side and an 1/8 of an inch on the passenger’s side. The first picture is before and the second is after the fix. The third picture shows the fender bolt after the1/8 inch adjustment.
Mine was the same, 10 min and a 10mm ratchet fixed it
DBRanger
Springfield, Ohio
The SuperCrew has the stitching on the rear seats.
