Exhaust tip for 2021 Tremor
OHTREMOR
Ohio
2021 Ranger Tremor
What is the correct size to order an exhaust tip for my 21 Tremor?
SEkevin
Kevin
Minnesota
Ford Explorer, 2021 Ranger Tremor Lariat
Healthcare
I believe it’s 3 inches
Dr3wDrop
Andrew
OHIO
2021 Lariat Tremor
Interested in this thread as well!
bk23103
Ben
2021 Ranger XLT Tremor - Cactus Grey
Emergency Services
This is an easy fix for the steel fence post that is the stock exhaust pipe for my nearly $50K truck. I've had the truck for a day and a half and I can already tell this forum is going to give me all sorts of ideas on how to spend more money!
Dr3wDrop
Andrew
OHIO
2021 Lariat Tremor
Bsqrd
Arizona
2020 Ford Ranger SuperCrew Lariat FX4
Pictures? I am looking to see if people trim the oem exhaust or just slip this on and have it double sleeved so to speak.
Didn't trim it. Wanted to see how it looks before I start hacking up the exhaust.
SEkevin
Kevin
Minnesota
Healthcare
OregonRangerTremor
Craig
2021 Ranger Tremor/2022 Bronco/2006 ChargerDaytona
Retired LEO/Dog Trainer
I got this one. It slips on about as tight as you would expect. The issue is that you get the bolt as tight as you can...and you can still pull it off. Like many I have got in the past; I will go to an exhaust shop, cut off 2-3" of pipe and have them weld this on. It does look good on the Tremor with all the black trim on the truck.
Amazon.com: AUTOSAVER88 3 Inch Inlet Black Exhaust Tip, 3" Inlet 4.5" Outlet 9" Overall Length Stainless Steel Exhaust Tips Powder Coated Finish Tailpipe : Automotive
OregonRangerTremor
Craig
Could do it either way. I will probably trim 2-3" off the tail pipe...it will still leave some double sleeving inside.
Bob902
St. Louis
RETIRED!!!!
That's why we are here!
Danager
Dan
Alberta
2019 Edge
Manager
I used the Go Rhino GRT3414B. Initially I just slid it on. A couple days later, I cut off 3-4 inches of the factory pipe. This allowed the new one to tuck in so it did not stick out at all. Probably not as proud as the factory piece.
JohnnyO
Jon
Pittsburgh, PA
2020 Ranger STX 4x4
