2020 DS Ranger
Did you buy the kit already to install or the one that you have to disassemble your strut?Installed Eibach's on my Ranger yesterday set at 1.5". Much improve ride!
What size tire are you running with the 1.5" setup? Looks perfectInstalled Eibach's on my Ranger yesterday set at 1.5". Much improve ride!
I was going to get a set from them, but their communication wasn't very good so I will look elsewhere. if I am spending that much money I want to feel good about the company.Stage 3 Motorsports, but I would highly suggest another source. Their customer service is terrible and I will never buy from them again! Tire Rack is a little more and their service is top notch!
Yes, very easy to adjust them down.Has anyone needed to adjust their headlights following a modest lift? I just installed front Bilstein 5100's on my XLT at the max (2.5") setting. I really like them, but the headlight pattern has moved up quite a bit, and I don't want to blind anyone. No one has flashed me yet, but I have the Auxito LEDs and they are pretty bright.
Thanks, did you need to adjust yours?Yes, very easy to adjust them down.
2.5" level kit installed. I had to turn the adjusting screw 4 complete rotations to get people to stop flashing me. I used a sharpie to mark the bolt head and just kept turning the adjuster screw. At first I only did two rotations but it was still a bit high for some other drivers.Thanks, did you need to adjust yours?
I did. Don’t remember how many turns of the adjuster screw but it was more than one.Thanks, did you need to adjust yours?
Yeah, I had to adjust mine after 3.5 inch lift. I don't have the distance so I did it in the front of the garage. I took 1.5 inch painter tape mark the line on the light against the garage door and adjust it to the bottom of the tape. Had to do it twice.Has anyone needed to adjust their headlights following a modest lift? I just installed front Bilstein 5100's on my XLT at the max (2.5") setting. I really like them, but the headlight pattern has moved up quite a bit, and I don't want to blind anyone. No one has flashed me yet, but I have the Auxito LEDs and they are pretty bright.
Looks good, I know its been a bit since you posted, but I just bInstalled Eibach's on my Ranger yesterday set at 1.5". Much improve ride!
Looks good, I know its been a bit, but I just bought the exact same truck used, and would like to set it exactly as you have, can send me the exact product(s) you bought, and did you do all 4 wheels? thanks a tonInstalled Eibach's on my Ranger yesterday set at 1.5". Much improve ride!
Part number included?Installed Eibach's on my Ranger yesterday set at 1.5". Much improve ride!
also what size tires are you running?Installed Eibach's on my Ranger yesterday set at 1.5". Much improve ride!
