Dynographs for the 2.3L EcoBoost Ranger - Dyno Compilation
Racket
Here and There
2019 Lariat Supercrew 2WD
Transient
Attached is my Ranger on 93 octane stock, tune, and tune with off the shelf octane booster (with AFE charge pipes and 3" cat back exhaust). These are all on a set of heavy Fuel wheels and tires. 0-60 is 5.7 seconds with traction issues. Stay tuned as big things are coming for this truck in the next couple of weeks that will require sticky tires and track time....and a good amount more power.
You're near me. We should compare notes although y goals might slightly different.
RamblinnMann
SoCal
2020 XLT FX4
Design Engineer
The EcoBoost vehicles advertised horsepower and torque from the factory are typically achieved using 91+ octane premium fuel. So the factory calibration is set up to take full advantage of running premium fuels even without a custom tune for premium. Then when you run these engines on low octane fuels such as 87 it's been dyno proven on the 2.3L Mustang that they can lose roughly 15-20% of Ford's stock HP ratings from lack of octane.
They start out commanding timing for premium and then if it's showing signs of low octane such as elevated knock it has to basically de-tune it self pulling out power and efficiency to prevent catastrophic failure from lack of octane. They also usually include right in the owners manuals that 87 is the lowest octane that can be used safely and that 91 plus octane premium fuels are suggested to get the best performance and efficiency possible, especially when in more sever situations such as towing for example. So it's definitely going to always perform to the best of it's abilities on premium fuel even on a factory calibration for both performance and fuel efficiency as well.
How might the engine react if you switch back and forth between different fuels depending on what you're doing? Say for commuting you run a lower octane fuel but when you want to do a weekend trip or want more power adventuring you switch to 91 occasionally?
Livernois Motorsports
Dearborn Heights, MI
2019 F150
The EcoBoost vehicles have a learned octane rating (LOR) that actually learns your fuel quality while you drive. Most all the EB engines we work with use this adaptive timing system and also have an OAR octane adjust ratio used for ignition and load/boost targets. These readings along with knock allow the EB engines to add and subtract timing / boost as needed to adjust for changes in fuel quality. So the higher octane fuels allow the truck to perform as it should adding timing and boost as it sees fit. Then adding low octane into the equation means the truck sees knock and also senses this through the LOR / OAR areas of the calibration to pull out power as needed. So they always run best on premium fuels since it's not having to limit power based on lack of octane basically.
RamblinnMann
SoCal
2020 XLT FX4
Design Engineer
Thanks for the clarification. Sounds like I could switch back and forth and the engine should pick up on the fuel quality pretty quickly and tune accordingly. I am going to try 91 as I'm curious about the power difference and whether it yields better mpg/range as well. Right now I'm getting 20 average with 87.
2019 F150
No problem, happy to help!
Yes switching octanes is no problem on the factory tune since it can adjust from 87 zero ethanol all the way up to 100+ octane unleaded race fuel and / or with up to 15% ethanol stock. Then we have custom tunes that allow for a range of adjustment from 87-89 or 91+ premium as well. So you'd need to switch tunes to take full advantage of premium if you were running an 87-89 octane tune for example. We have several customers on another Livernois Tuning thread a customer started saying they are seeing a couple miles per gallon better than stock with just a tune and premium fuel. One gentleman said best he could get on the stock cal was around 20 and now he's seeing over 22 doing an average of 65-85 MPH on the freeway. Here's the thread for a bit more feedback https://www.ranger5g.com/forum/threads/livernois-tuning-released.2036
RamblinnMann
SoCal
2020 XLT FX4
Design Engineer
Thanks for the link! I've started to read through that thread as well! Some people in the thread said it could take a few weeks (or tanks) for the engine to adjust to higher octane - is this true?
Also, would you expect to see a huge jump in performance/response between 87 and 89? Or is it more of a small jump between 87 and 89, then a larger jump between 89 and 91? Just trying to gauge relative levels of standard performance and the balance between performance/mpg and fuel costs haha!
2019 F150
No problem, happy to help out!
The adaptive learning curve after flashing / programming can take a week or so for the truck to fully adapt to the tuning and relearn how you drive again custom tuning wise, really depends on miles driven a day also. On the stock cal since it's not being reset adaptive wise it can take a bit longer for the truck to adjust if it's just a change in octane. So most guys that say they've run a tank or two before they really start to notice the differences depending on how low the tank was when you switched fuels. If you have a mixed tank of low / high octane it can take longer.
The most noticeable difference is going from regular to premium fuels. Just changing from 87 to 89 wouldn't make a huge difference since it's really targeting premium fuel to get the full extent of what the truck can perform like stock cal wise.
RamblinnMann
SoCal
2020 XLT FX4
Design Engineer
I read through the thread that you linked and it looks like you've got great reviews and many awesome benefits to your tune! It's definitely got me thinking!
After reading a bit more, I would probably still want to run 87 since it's the cheapest by a long shot where I live, but being able to get more mpg out of 87 would be great.
How do your tunes do off road? Is there a specific tune that you'd recommend (soft tune vs. performance) for off-road driving?
2019 F150
Thanks for the kind words and for considering our products and services!
We do offer tunes suitable for use with any fuels 87 octane or higher in performance and towing versions as well. We can also apply optional adjustments as you've mentioned for softer shifting, start stop on or off. Fuel mileage is not something we publish estimated gains on since vehicles, conditions, and drivers vary which can play a huge role in mileage. I've had average customer's feedback lately of roughly 1-2 MPG better than stock which is great, some say slightly more, some less.
I've had a few customers that said they've taken their trucks off road with the tune installed and had a blast as well! It's really all user's preference but the towing tune would be a great tune in my opinion since it's slightly less aggressive on shifting and more geared towards low end grunt for towing and hauling significant amounts of weight. Feel free to give us a call , PM, or email if you'd like to discuss the tunes a bit further in depth or place an order as well and we would be happy to help out!
mattr66
Matt
TX
All Kinds of Ecoboost Vehicles and Diesels
Tuner
Here's a dyno session of a stock truck with catback exhaust, then tuned, then tuned with the Gearhead prototype turbo upgrade. All runs were on 93 octane. With the stock turbo, optimum shift point for maximum acceleration is 5600 rpms, after turbo upgrade, wot shift points are 6100-6200 rpms depending on gear change. Tuning available on SCT or HPT.
landiscarrier
Landis
Pocono Mtns Pa
2025 Ranger Raptor
Sales
I've been running Matt at Gearheads tune for about a month now and I absolutely love it! The truck drives and shifts better than stock (very smooth) but when you step on it or put it in sport mode.....what a difference! Oh and my MPG went up too!
Ace Holliday
Scott K
South Kalifornikstan
2019 Ranger XLT Super Crew
Before and after installation of the FP Tune. Only other engine modification is a Flowmaster 40 Series muffler.
BJMartin
BJ
NW OKC
2019 Ford Ranger XLT, 2007 Ford Mustang GT
Marketing Strategist
Got the Ranger dynoed today. Mods are Tuning by OZ Tuning, aFe catless downpipe, and e30. Truck drives amazing and I know I can trust the reliability of Kens tune. Before adding the downpipe it put down 313hp/379tq. Now I’m setting right where I want to be at 337hp/420tq.
