Driveshaft Phasing
HarryD
Western MA
The tech was actually driving and we did get up to 80 MPH, but I can feel it starting at around 60 on a smooth road.
OKRaptor
Scott
Oklahoma
2020 F-150 XLT, 2019 Acura RDX and a 2007 Mazda Miata w/turbo
Just curious , what speed did you drive to show the tech? Between 70-80 is very noticeable with my truck.
My vibration was in the same speed range.
2000rpm
Brad
United States
2020 Ford Ranger, 2019 Ford Flex
I climbed today under my 2020 XLT and noticed the same out of phase situation with the rear-most driveshaft section (as in the video by the OP). I can't say I'm noticing any vibration though.
RngrRegmnt586
Roy
So Cal
2019 Ford Ranger Fx4
No, but they need to address the vibration issue.
Welcome to the vibration nation.
Btw, I'm not stock. Eibach Pro with fifteen52 Traverse HD's and Falken Wildpeaks @ 265/70-17's. Now, I actually experienced this vibration when I bought the truck STOCK. I initially had the dealer balance the factory/stock wheels and tires twice. Then I put my aftermarket stuff on and the bigger tires only accentuated the vibration since the rotating mass and circumference increased. I thought the new wheels and tires were the cause so I installed hub-centric rings. Nope, still there. Balanced the new rollers THREE TIMES and nothing.
I first got my vibration after installing Icon coilovers (adj. to 3" of lift), Icon UCAs, and 285/70/17 tires on RTR wheels. The vibration is felt between 60 to 80 mph. Haven't gone above 80mph. Truck was fine with ONLY Icon coilovers installed at the out of the box height of 2".
This is my 3rd Ford and I'm tired of being lied straight to my face by a technician who says he cannot see or feel the issue and/or sorry but we cannot "replicate" the problem so in essence... you're lying to us.
Hi Roy,
So you have stated that you were okay after lifting the truck but after the tires/wheels you have a vibration, correct? Then you and the tech need to focus on the tires/wheels as the likely source for the vibration, eh?
Rp930
Denver
[/QUOTE
Just to clarify, are you expecting the dealer to fix your modified vehicle under warranty?
RngrRegmnt586
Roy
So Cal
Had the factory wheels/tires on before AND after the final suspension work was done. Never had an issue with the factory wheels and tires prior so I didn't even consider that it would be a wheel/tire issue when they were STILL on the truck when the vibration began AFTER the coilover adjustment and UCA install.
And no.... I don't expect anything from Ford at this point of my build. I think what I might do is crank the coilovers back down to around 2", realign, and see if that alleviates the problem.
Eh... fingers crossed.
OKRaptor
Scott
Oklahoma
Was?? How did you fix?
Traded it in on a 2020 F-150 XLT - Problem solved :like:
Gotta say, the F-150 rides nice, has plenty of power and more space. But, I do miss driving a smaller truck and the fiestiness of the 2.3L
Rp930
Denver
That sounds reasonable.
RobmJ
Austin
Yeah I had an F-150 as my loaner when they were inspecting my truck , and I noticed it wasn’t nearly as bouncy, brakes were much more responsive , ride was smooth and solid.
CO2Ranger
Longer wheelbase will smooth the ride out quite a bit.
It's pretty apparent the F-150 is Ford's baby. That's where the money is.
HarryD
Western MA
The next problem, after getting a service tech to "actually feel the vibration" is their next step in diagnosis. Next they would fit the truck with some sort of vibration detector (I don't recall the name of it). If this device detects vibration below a certain limit, nothing will be done about it.
rdgallo
Ron
Morton, Illinois
Accelerometer?
HarryD
Western MA
The device may contain a fairly sensitive accelerometer, but it sounds like a test box that also has recording capability.
