- Joined
- Aug 24, 2022
- Threads
- 28
- Messages
- 4,561
- Reaction score
- 8,704
- Location
- Midwest - KS
- Vehicle(s)
- 2022 Ranger Lariat-Super Crew, Cactus Gray
- Occupation
- Aircraft Tech
This is most likely the issue, but the only way to confirm is wire checks and even jump power to the Low Beam circuit as a test.This is what is so confusing and makes it seem like something internal in the headlight assembly. Why does it shut down in low beam and still work in high beam
The way Bi-LED Projectors work is they have one LED that is used anytime the headlights are on and have a shutter assembly that drops down into the beam to create the cutoff line for low beam.
The headlights the OP has have three of these assembles in each light. All I can think of is a thermal break in the traces on the control board in the light that when the the shutters are activated it turns off the LEDs. Then after the lights have been off for a while the break closes and the lights work again and they work again until the heat up again. Has to be on the main control board as all three of the Bi-LED unit in the light are affected together.
Hopefully the vendor will get you a new assembly to replace the one not working correctly. I know having to change it out is a PITA. If it was a FORScan setting issue I think it would affect both lights the same.
Moreso - Highly Needed as they are a PITA to replace.
Yes, it is a shutter control using the same (LED) but there is still a separate power source for each light output - if the BCM dumps power for the Low Beam, then the Low Beam will become inoperative. As the BCM is still programed as if there is a (Separate Low Beam) Bulb installed.
The Halos - Tie in DRL's into the Low Beams @ 50% Power and Aftermarkets tie in a (Tapped) power source on that DRL Circuit.
So, you have a Tapped Power source feeding on a circuit (DRL) that the BCM sees as it should be (OFF) as the Headlights are (ON)
The BCM decides that there is an issue on the circuit and dumps power, yes it would make sense that it should affect both Left & Right sides, but history of issues on this forum show if issues arise with the headlights (It is almost always the (LEFT SIDE)
So, for the OP - When you installed the lights - Did you (ft Deselect) the DRL Option (Turn-Off) in the IPC Menu?
This may fix your issue, but it must remain (Turned Off)
This is the circuit that is causing the issues - The Tapped Power source on DRL circuit that the BCM still is programed for Low Beams, The IPC Menu turns off the DRL's but the BCM is still programed and unless you change the As-Built Data, it will remain that way.
Selecting (Off) the DRL in the IPC, May or May Not fix the issue, but it is something to try.
