Drive train fluid replacement
Cmar
Cam
Australia
Ford Ranger PX
Medical Scientist
I did mine at ~100,000 Km. Result:
Rear Diff - dirty, a reasonable amount of mud on the magnet but no flakes
Front - almost clean, minimal mud on the plug
Transfer case - dirty, quite dirty, in fact
Gearbox - dirty, did 3x drain and fill three weekends in a row, managing to get ~ 4 liters out each time with a suction tool, last one was pretty much clean
Will probably do at ~ 50,000 Km from now on.
TruckNorris
Brad
NC
21XLT FX4
Technician
Where can we find instructions on replacing the fluid and filter? Thank you. Also how much would it cost to have the dealersship do it?
Peter949
Peter
Irvine, CA
2024 Ranger Raptor
Find a reputable mechanic. Most dealerships don't replace filters for trans just empty and fill.
AJC
Armand
2019 Ford Ranger Lariet
My dealer quoted 639.80 for both differentals, transmission and transfer case.
Fx4ranger2019Larait
Ricky
SoCal
2019 Ranger FX4 Larait
Sprinkler Fitter
RAYJAY
UNION DALE PA
2020 ranger pickup 2019 subaru
there is a couple of write up on here just have to search .
RAYJAY
UNION DALE PA
ctechbob
Shawn
2020 Ranger XL/FX2/STX
Adult Daycare
Just ignore all the disassembly stuff. There is nothing in the way of our pan (coolers/hoses/etc). Unbolt, remove filter, reinstall filter, bolt back together, fill......
Very simple.
Even easier to do if you replace the pan with one of the aftermarket versions. Even Dorman makes a plastic replacement with a drain plug for $70, or you can go aluminum for $300+.
JohnnyO
Jon
Pittsburgh, PA
2020 Ranger STX 4x4
I did the axles and transfer case at 30k. Rear and t-case looked like tar but I expected that as I've done it on other trucks I've had before. Trans I'm holding off on for now due to cost, I'm not sure about doing it myself and in my old Sport Trac I had the fluid flushed three times and it still broke at 132k so I don't know that it makes any difference on a Ford tranny. I may do it at half the recommended interval at 75k.
FWIW, the only aftermarket synthetics I found that meet the Ford specs in the owner's manual are Redline 75w-90 for the axles and Redline D6 ATF for the transfer case. Front diff takes about 1 quart and the rear a bit less than 2 quarts. You can get them from Amazon.
That is why you don't flush a transmission. Just drain and fill. You will be amazed at how one will do when you do just that
ctechbob
Shawn
Adult Daycare
You'll want to do it before then.
I'm almost willing to bet we're going to see Ford moving their 150k interval downward.
Don't hold your breath on that as you may suffocate and dies ???
Burnt Money
Andy
Charleston SC
2020 Ranger XLT FX4
Does anybody know what the fluid capacity is for the transfer case? There is this that was posted by one user from what appears to be a shop manual.
https://www.ranger5g.com/forum/attachments/transfer-case-specifications-pdf.31154/ that says 1.2 liters (40.5 ounces ). My owners manual says 23.67oz. Others have said fill till it runs out. I’ve always done the fill to spill method on other vehicles. I’m just not sure what kind of sorcery is going on inside the Rangers transfer case and don’t want to jack anything up. I changed it yesterday and filled it to the owners manual. Then I started reading on the forum last night and it got me wondering lol.
Colo_Ranger
2021 Ford Ranger XLT FX4
I did the fill and spill method, I believe it was less than 2 quarts, but don't quote me on that...
RAYJAY
UNION DALE PA
same here a little under 2 quarts .. and i used redline oil for transfer case and diffs
