Check The Torque On Rear Leaf Spring U Bolts!
deleriumtremor
Bill
Boise ID
2022 Ford Ranger XLT FX4
I checked the torque on my truck and discovered an odd thing. The two bolts on the front side of the axel were tight to the point that I don’t know what touque they were set to, for sure it is over 98 ft ibs. The other two, the back/rear of the axel around started 70ish. Brought those up to 98 and went out for a drive. Came back and retested. I found that the two nuts on the front side of the axel were still tighter than 98. The two on the rear side had loosened and needed to be further tightened. They needed a surprising amount of additional tightening.
Does this indicate a specific problem? Should I drive for several days and retest again or just let it be? Is it a problem if the nuts on the front side of the axel are set different to those on the back side of the axel ?
Not being a smart as here, but…
It might just as likely indicate an issue with the torquer than the Torquee.
But interesting results, none the less.
Good luck.
RangerTX
Illinois
2021 Ranger Lariat FX4
As a torquee, one should twerk while you torque. It will work better.
I gotta say - the more I scour these forums, the more I am very concerned at Ford's QC.
ambit
Philly
2021 Ranger SCAB 4x4
I tightened mine today at 10,000mi and it seems to have cleared up a clunk I had at start/stop.
JCMAC
Richmond Ontario Canada
2019 Black Ford Ranger Lariat FX4, Sport Pack
Retired Systems Analyst
Did anyone who checked ubolt nut torque notice if the forward ubolt nuts were to spec (98ft/lbs) and the trailing nuts were loose (74 Ft/lbs) as happened in my case?
zzapd
Patrick
Illinois
2019 Ranger XLT
Saw this thread and decided to check my 19. Eight nuts one just above 54 and the rest just below 74 foot pounds. After torquing to spec it did feel a little less soft under power. Or just my imagination.
ok so next weekend im going in with the t wrench in hand lol. i figure just make sure they all click at 94 and call it done. this forum is giving me so many more things to check and wonder about... :crackup:
Reactions: R_B
Racket
Here and There
2019 Lariat Supercrew 2WD
Transient
Is the consensus to re-toraue the factory nuts or seek out the 'quality aftermarket' u-bolt/nuts?
Would there be some 'upgrade' version?
I have been loading and towing a bit lately on top of mixed driving and would want to be proactive in prevention.
