deleriumtremor
Not being a smart as here, but…I checked the torque on my truck and discovered an odd thing. The two bolts on the front side of the axel were tight to the point that I don’t know what touque they were set to, for sure it is over 98 ft ibs. The other two, the back/rear of the axel around started 70ish. Brought those up to 98 and went out for a drive. Came back and retested. I found that the two nuts on the front side of the axel were still tighter than 98. The two on the rear side had loosened and needed to be further tightened. They needed a surprising amount of additional tightening.
Does this indicate a specific problem? Should I drive for several days and retest again or just let it be? Is it a problem if the nuts on the front side of the axel are set different to those on the back side of the axel ?
It might just as likely indicate an issue with the torquer than the Torquee.
But interesting results, none the less.
Good luck.
