Yinzcity
- First Name
- W
- Joined
- Oct 8, 2021
- Threads
- 11
- Messages
- 199
- Reaction score
- 429
- Location
- Detroit, MI
- Vehicle(s)
- 2019 Ranger Lariat
- Occupation
- Engineer
I suspect I'm having the same issue with my 2019 Lariat. I get a shutter/misfire around approximately 25-45mph if the engine speed is under 2000 RPM and I apply just a little bit of gas. Easiest to replicate when rolling along a flat road. If I find the right "spot" I can get it to misfire for a few seconds until I change my throttle input or the road changes, but never any codes. Forscan shows misfires evenly across all cylinders, 6-15 counts in a 1/2hr drive. I replaced the plugs and checked the coil connections with no luck. Same with clearing the adaptive trans tables in Forscan. Its been at the dealer since Wednesday, they were able to replicate the issue, they also replaced the plugs without fixing it. Apparently they are talking with Ford about it now, mentioned they were looking at shimming the rear axle or something too. Will report back with what fixed it when its done.
