Bludrok's Performance Tremor Build
dondonbabyraptor
Brandon
San Diego
2020 Ford Ranger Lariat
I/O Psych MSc student
I'm at 5000 miles now, and put it on around 1000, I think? No issues. It really woke up the exhaust, which the MBRP is a mild toned exhaust. I wouldn't want it combined with an aggressive exhaust.
Interesting note. Thank you. My truck already makes cars alarms go off… but I really want this. I wish I was as mechanically inclined as you, I’ll have to send it to a shop to install.
Bludrok
Bludrok
Acampo, California
www.ranger5g.com
There are only 3 bolts, but getting to them sucks. Even if you had the skills and tools to do it, I wouldn't fault you for taking it to a shop.
Bludrok
Bludrok
Acampo, California
www.ranger5g.com
Current TOTAL investment! :-?
Dunno, don't want to know...?
Near 60k though. That includes my bumper, winch, and lighting setup I haven't installed yet though.
RBTremor
Rod
Detroit, MI
1966 Mustang Convertible, 2019 Mustang Conv. 2.3L
There will be many edits before my build is complete, but I was excited to start sharing.
Ordered in February, finally picked it up on Cinco de Mayo 2021 (May 5th)
Here are pictures at the dealership:
I didn't get home till late, but was excited to start my build, so I woke up early and started before heading to work.
Mishimoto Cold Air Intake:
TurboSmart Dual Port Blow-off Valve:
AVS Smoke Bugflector II:
HitchSafe:
I made a cable so the cover will never be lost if it falls off while driving. It is a Husky PVC Cable Saw tied to my tow package and the other end cut off.
First, I wrapped it and then tied the cable.
When pulled tight, this is how it looks. The handle from the cable saw is too big to fit through that opening, so it won't fall out.
I drilled a small hole into the center of the cover and then crimped a quick connect fitting that I cut off the end for. Gives it a professional look, while ensuring it holds the cover.
CravenSpeed - The Stubby Antenna:
RUXIFEY Side Mirror Puddle Light LED Lamp:
For the connections, I used heat shrink tubing that I filled with Di-electric grease prior to heating up the heat shrink. The excess you see in the picture was wiped away afterwards.
VIP MOTOZ Smoked Marker Lights
CupHolderHero Cup Holder Inserts
MBRP Dual Split Rear Exit Cat-back Exhaust
4WDKing Underbody Lights
Mishimoto Catch Can
Mishimoto Performance Intercooler and charge pipes
DEE ZEE Tailgate Assist
@AzScorpion I want my T-Shirt! ?
Added some decals (More to follow):
Relocated the Securicode Keypad. It was easy to remove using dental floss, then I cleaned the excess glue using alchohol. Used 3m VHB tape to apply inside the gas door.
SPD Performance Downpipe
The downpipe said it had a 3" pipe with an adapter to 2.5", but the adapter was actually welded on. I cut off the adapter to have a true 3" exhaust.
Make sure you have an impact wrench, plenty of swivels and extensions if you are going to replace the downpipe. It is a B***h to get out. I used 20" of extensions and i think as many as 3 swivels for the most difficult nut.
Since the MBRP exhaust did not come with a front pipe, I purchased a new flex adaptor and 5' Stainless straight pipe. I connected the flex pipe to the downpipe and then the straight pipe runs back to the muffler.
Here is the flex pipe:
This is the straight pipe running back to the exhaust.
I connected the pipes together using these lap band clamps.
One note I will make for anyone doing this. In the picture showing the flex pipe, there is a hanger bracket on the other side that is not currently used. That's why the pipe is so close to the frame. I am going to take it to an exhaust shop to have them weld a hanger so I can use the stock bracket to prevent it from banging of the frame when I hit a bump.
BuiltRight Industries Bedside Racks:
Raised Tailgate Letters
Gorilla Automotive Acorn Lug Nuts in Black Chrome and matching Wheel Locks
Wireless Charging Pad - Credit @DirkM (Wireless Android Auto to come)
RokBlokz Black XL Mud Flaps with Red Lettering:
Auto folding Mirrors Module
(I put it all together without any pictures, so this is just showing them folded):
Front Grill Inserts:
More Decals:
5-Star Tuning BDX Tuner with Tunes: 87 Daily/Tow - 91 Daily/Tow - 91 Performance:
Vinyl Dash Inserts:
Rostra Ford SYNC® 3 8” LCD Multi-Camera Video Interface:
NATIKA Camera for Drivers-side Mirror - Activated by left turn signal
NATIKA Camera for Passenger side mirror - Activated by right turn signal
For a detailed process of the side view mirror install CLICK HERE.
NATIKA Camera for Front of Truck
(Installed, but only with zip ties for now. Will upload pictures once permanently installed on my new bumper)
Rough Country Differential Skid Plate:
Rac N Cap Ladder Rack/Tonneau cover
Flags to show my patriotism:
(My son gave his blessing?)
AuxBeam 7" Ditch Lights:
Still to come:
Addictive Desert Designs Stealth Fighter Winch Bumper with Sensor Cut-outs and ACC relocation bracket
RUN-D Amber Cube Led Driving Lights 3 inch CREE Off Road Lights (Amber LED)
Arsenal No.1 40 inch Curved 228W Pro Series LED Light Bar
Fumoto Original F107N with LC-10 Lever Clip FN-Series Engine Oil Drain Valve
Window Tint
Nice, Where did you get the rear window flag?? Love it!!
Bludrok
Bludrok
Acampo, California
www.ranger5g.com
Ds_2020Ranger
2020 Ranger XL FX4
Any issues with the rough country dif skid plate install? Any modifying required since I think its made for the Jeep M220? Any pics?
Thanks.
Bludrok
Bludrok
Acampo, California
www.ranger5g.com
Thanks.
No issues. However, I did purchase longer grade 8 bolts and use washers as spacers for the front support bracket. Otherwise you will bend it over the driveline.
I'll try to upload some pics for you this weekend.
Bludrok
Bludrok
Acampo, California
www.ranger5g.com
Forgot to mention the most important part. Installed my Tires and Wheels :sunglasses:
Pro Comp 69's and Nitto Ridge Grappler 315/75R16
You posted this without pictures? That's blasphemy.
All pictures are in the original post. I edit it each time I add something, that way you can see the entire progression without having to search through the thread.
I make the notification post so it bumps the thread, and notifies those who are following it that there is an update.
Colo_Ranger
2021 Ford Ranger XLT FX4
