Biggest tires, no lift?
Superbj
Bryan
Minnesota
Seems like a majority of the posts have a starting OEM tire of 265. My truck has OEM 255/65R17; it's a standard XLT without a Sport or FX4 package. Does anyone know if there are Ford manufacturing technical differences in the suspension? Obviously I am also trying to sort out what will fit, but I am not sure if my starting point is different than those of you are are already fitted with a 265 tire directly from Ford.
LaKings
Gary
Los Angeles
2019 Ranger XLT
Has anyone on here put on Falken Wildpeak AT4s 265/70/17 on their 4x4 XLT? These seem to be in my budget and I just need to be sure they won’t rub using my stock sport wheels. TIA!
PrimeRanger7
Sonny
Canada
2019 Ford Ranger Lariat
Environmental
These would do perfect with no rubbage. Any bigger you’ll rub for sure. Unless you add a level kit !
PrimeRanger7
Sonny
Canada
Environmental
How much bigger can we go with no lift? Looking at 265/70/17 which are 31.6 vs the stock 265/65/17 which are 30.5. so that only equates to 1/2" difference in diameter approx.
PrimeRanger7
Sonny
Canada
Environmental
Hey sir. 265-70s are just right with out the front tires rubbing. If you go 285 it’ll rub. Unless you put on a level kit
LaKings
Gary
Los Angeles
2019 Ranger XLT
thx. I read somewhere that the AT4 is beefier than the discontinued AT3 so I was hoping someone on here has them on.
Bob902
St. Louis
RETIRED!!!!
I have the AT4 in 255/70/18. Had them for over a year now. Very impressed
TxOTRRanger
Clay
Elwood, Texas
factory worker Tyson Foods
I went an inch bigger in diameter 31.5” with 265/65/18 Duratracs
The stock one was 30.5” 265/60/18 Hankook Dynapro
No issues so far at 140 plus miles.
I think the issue would be the width, so I checked this first
https://tiresize.com/comparison/
According to the size calculator, the width is the same with the tires I chose.
Thanks for sharing this, that answered the question I had rattling around inside my head. My truck has 255/65/17s and I am probably going to go 255/70/17s on the next set of tires. Nice ride man.
TxOTRRanger
Clay
Elwood, Texas
no spacers, no lift, no level. As stated before, my intention was to install a taller wider tire without throwing the gear ratio out of whack too far, so I went with a tire only 1" taller than stock, and about .8" wider. These are Cooper AT3's, a true light truck tire (10 ply rated). After driving home from discount tire, it's clear that these I think are perfect for as far as my stated goals were concerned with the existing gears and maintaining the "zippiness" of the motor. No doubt a 265/70/17 would look better, however I like the width of the new tires and again the preservation of performance as it relates to the original gear ratio. I also intend to pull a travel trailer so it made a difference to me as to how tall of a tire I should install.
I like the way that looks. 1" and retains the power of the truck itself. I was planning on getting a set 255/70/17 Goodyears on the next set of tires, but I really like the way 275/65/17s look. My truck spends most of its life on the road, and with a setup like yours it will retain the power and still have the 1" lift.?
TxOTRRanger
Clay
Elwood, Texas
Its standard with a Sport package, I have a 22 Sport 4x4 and it has 255/65R17s on it. I have researched the heck out of this thread and made up my mind and I am going to put a set of 255/70R17 Goodyear Wrangler highway tires on the next set.
