Biggest tires, no lift?
Stic-o
Lake View Terrace, CA
How much bigger can we go with no lift? Looking at 265/70/17 which are 31.6 vs the stock 265/65/17 which are 30.5. so that only equates to 1/2" difference in diameter approx.
MadMartigan
NY
Ford
I'd love to know the answer to this also. And if anybody has pics of larger tires without lift
KnightRanger
USA
2020 Ford Ranger, 2016 Harley FLSS,
I went an inch bigger in diameter 31.5” with 265/65/18 Duratracs
The stock one was 30.5” 265/60/18 Hankook Dynapro
No issues so far at 140 plus miles.
I think the issue would be the width, so I checked this first
https://tiresize.com/comparison/
According to the size calculator, the width is the same with the tires I chose.
gfitzge2
Gregg
Louisville, Kentucky
Retired Electrician
Has anyone tried 275/65 R17 ??
Fjsteven
Steven
Gilbert, Arizona
2019 Ranger Lariat 4x4 Sport
Interested too. Should have my truck in about a week. Tires will be the first thing.
FlRanger
South Florida
2019 Ford Ranger Lariat
Let us know! I like my color match rims but would definitely like some beefier tires.
MadMartigan
NY
Ford
Still haven't found a dedefiniti answer to how big you can go on the sport 17 wheels(current 255/65) without a any mods/lifts/levels.
I may just order some 265/70 and take my chances. I can't imagine that would be an issue as the FX4 tires are 265/65. That's dam close. Worst case i'll just level the front if I have to
Also do you need to upgrade the spare? Or because it's a temp it's not a problem to run a bit lower diameter tire for a short time.
265/70-17 Hankook DYNAPRO ATM RF10 is a factory option on my order. I'll be running that until I find the proper lift then I'll mount my 285/70-17:like:
doug910
Detroit, MI
'19 Ranger, '02 BMW 540i
You should definitely upgrade the spare. Your spider gears in your diff will absolutely hate you if you run a different diameter. However, it does suck buying a brand new tire just to be used as a spare, so I would recommend getting a cheap used tire that is the same size to mount as a spare. It should do the job in a pinch. That's what I'm planning to do at least!
MadMartigan
NY
Ford
Does anyone know if a 285/65-17 + 20 offset wheel and trimmed deflection beams would fit without lift? Or is this just not physically possible?
RJohans
Bend, Oregon, USA
2019 Ford Ranger Lariat 4x4 Supercrew Sport
If the crash bars are "modified" and one can fit that fat wheel/tire combo inside the stock front wheel well, is it possible to lower the rear to get to level? That is, lower the rear rather than lifting the front?
