Battery Replacement
dozxab
Prescott AZ
Muscleford
George
Ohio north coast
Retired CFO
Had my new battery installed yesterday at the auto parts store. When I got home I did the flash bright lights 5 times, press the brake 3 times but did not get the flashing battery light, the battery light stayed steady lit.
Do I have an issue??
Thanks for the reply.
George
dozxab
Prescott AZ
George
Try again, it has to be done in a short time and exactly right. There was a similar 3 step process to program keys in the previous gen Ranger and sometimes it took 2 or 3 tries. Except for Chris, he nailed it every time!
Muscleford
George
Ohio north coast
Retired CFO
I did it again and got the flashing battery right at the last brake pump.
Thanks.
seanellaz
Sean
Tucson, AZ
Healthcare
It appears that it may be time to replace my battery. My truck is a '21 with the original battery. I got a message on the screen yesterday but I caught it out of the corner of my eye while starting the truck. It was something about starting the truck to......something about the battery. It went away as soon as the truck was started.
I understand that Motorcraft batteries are not the best quality. So, would the average employee at O'Reilly or Autozone be capable of replacing it without issue?
I also believe two different physical size batteries were used in Rangers, how to tell which size you have?
What has to be done when replacing it? Any resets that need done? I do not have Forscan.
Thanks.
George
While you are at it, consider upsizing to larger battery which comes stock on the Lariat, I got this battery from Costco in 2023, 1355852 G H7(94R). I don't think I did the forscan mod to tell the BMS that the battery is the big one. I think the BMS reduces charging at engine full load to make some additional power available to push the truck, the adds charging when not under full load.
RangerBill
The BMS charges at a higher rate when coasting to allow the truck's momentum to drive the engine and alternator, which is supposed to save fuel.
