Backfiring after installing K&N filter
Jason B
Louisiana
2021 XL STX SE 4x2
machinist
I did run the K&N for a couple of months after flashing the FFP tune but then returned to the stock Motorcraft filter, not because of any (noticeable) problems, but because I was concerned about the "freer-flow" K&N letting more particles "freely flow" into my engine.
I think that's what most people mean when they say they want a CAI, because automakers have been using CAI on their engines for a long time. Even my 1995 F150 had it.
And that box OP installed is not CAI if it is allowed to draw air from the top, inside the engine compartment. That box would work with an aftermarket hood with ram air.
Superdannyboy
XL GT
Manheim, Pennsylvania - Wildwood, NJ
21 Ranger STX
Civil Engineering Firm
Yeah, it sounds awfully counter-productive if it's drawing cooler air from the front intake tube, and sucking in hot air through the top under the hood. It's not really a CAI, it's kind of an LWI (Luke Warm Intake). But hey, you probably get stickers with it.
thomas461
Pete
Cumming, GA
2019 Ford Ranger XLT, 1998 Ford Ranger XL (Son)
Having run a lot of different turbo vehicles for a lot of years. My experience has been until you get to the point of changing the injectors and going with a larger turbo the factory air box is more than enough. In two previous cars going to a CAI actually caused the vehicle to lose HP/TQ because intake temperatures went up. I come from Subaru's (A lot of them), Turbo Supras, Turbo Datsun/Nissan's and Ford Turbo Coupes from the way back.
For every 1 degree of intake temp you gain or lose HP. If you are pulling air from under the hood the charge will be warmer going into the combustion chamber. This will cause the ECU to do a couple of things. More fuel to cool the charge since your EGT's will rise or it will cut the timing to prevent detonation (Knock) or it may even do both. Either/or results in loss of HP from your engine.
The engineers who manufacture these vehicles know what they are doing to get "everyday" HP numbers from these engines. They design the drivetrain (Intake, engine, Exhaust, Transmission, rear end) for a board range of uses (Daily Driving, Emissions, Towing, MPG, etc). CAI intakes are an expensive way to make more noise (not a fan) and not necessarily more HP.
Now if you have gone up to a full stand alone MOTEC ECU, Garrett G30-900, with dual fuel pumps with secondary fuel staging, cams, 1500CC injectors and a 4" stainless exhaust, the CAI will make a difference to your numbers.
If you are running your truck on the street everyday keep the dollars in your pocket. If you want performance find a good tuner and invest in a Custom Engine Tune for your vehicle. IMHO The best return on investment.
billwinkle
billwinkle
Bill
2021 Ford Ranger XLT 4X4 super cab
Just got back from a weekend run to Charlotte to see the Nascar hall of fame. On the way back ran 173 miles averaging 75 miles per. I show 22.6 miles to the gallon. And that is thru quite a bit of elevation changes. Truck ran great, no shift problems, did not even feel any turbo lag. I found the only time I could get it to backfire was to load up to WOT and immediately let off the throttle. I am thinking that I am loading up the intake with quite a bit of fuel and not giving the engine time to properly burn it off. If I would load up WOT and run for several seconds (like passing) not backfire.
Thank you everyone for some great info and conversation, I learned quite a bit. I may send this box back and go back to stock. Or maybe the Mishimoto, who knows. Maybe the Fox 2.0 setup, as I have a Leer shell coming in in a few weeks. Or maybe a intercooler, or ???????????
Cheers,
Hi Bill,
Direct injection into the cylinder..no fuel in the intake...
billwinkle
billwinkle
Bill
Hi Bill,
Stupid me I knew that. I shouldn't type out thoughts when tired.
If it's happening when you let off of full throttle it's afterfire. You're tune is probably a little rich. Better than being a little lean.
And our trucks, stock for stock, are NOT faster than a WRX or STi to 60.
billwinkle
billwinkle
Bill
That last part was just a little humor. I've driven subis from Stock to actual X-game racers (Crawford performance built). And they are fast little beasts.
That last part was just a little humor. I've driven subis from Stockton actual X-game racers. And they are fast little beasts.
You should be used to afterfire then. My blobeye afterfired some with just a catback let alone when I was done with it.
Funny thing is nobody else questioned it. Folks around here really think these trucks are fast. They are fast trucks, but they aren't fast.
