- Joined
- Aug 24, 2022
- Threads
- 28
- Messages
- 4,611
- Reaction score
- 8,798
- Location
- Midwest - KS
- Vehicle(s)
- 2022 Ranger Lariat-Super Crew, Cactus Gray
- Occupation
- Aircraft Tech
If you have (Auto-Dim) Mirror, then just the Dongar Adaptor is needed.Hey Guys, Heading down this path, especially since Wolfbox has 3 cameras now.
I see a lot of info on the mounts, just not the wiring connection. How did you connect wiring?
Any pics or suggestions. Didn't see any on the site either. and if the WolfBox is powered by USB, where does the OEM connector go?
Thanks,
jason
It is a T-Harness that will tap off of the (OE) connector and give you a connection to reconnect to the (Mirror) and a (USB) connection for the (Dashcam)
If you do (NOT) have the (Auto-Dim) mirror, then you will need to get a short (Factory Harness) that will supply (include) the (Auto-Dimming) mirror connector (PLUS) the Dongar Adaptor.
As stated above - this connection is (Switched Power) so if you want/need the activation of the cam (parking-recording) you will need to fuse tap the (BCM-Fuse Box)
If needed the Factory (Short Harness) = Output from C919 and feeds all connections behind the mirror (If you do not currently have a (Auto-Dim) mirror connector on the harness.
