Asking for Advise from Experienced Off Roaders
sts90
Theo
Ponchatoual, La
2020 Ford Ranger XLT FX4 SuperCrew
Clinical Engineering
What would you do to a stock 2020 FX4 Ranger to improve off road capabilities without messing it up as a daily driver?
Shocks/level and more aggressive tires. That’s all you really need
First thing I did was get new tires and a 2" level. I went up one size to 265/70/17 Nitto Ridge Grapplers and they're great off road and still very quiet and smooth on the road. It's also going to depend on what type of off roading you're going to do and how often you're doing it? Personally I don't mind the Fx4 suspension but some don't like it so if you're going off road a lot you might want to invest in better shocks. If you're only going out once every few months than a level and the stock suspension should be fine.
The only time I found it "bouncy" was on a trail that was really rocky, I mean more so than any one I've been on and I wished I had something smoother on that one. Other then that the level has worked out fine. We were on some fire roads last week and doing some higher speed driving, 50-60 at times and the suspension was perfect with traction control off.
So screw leveling kits as they are stupid and render a truck useless(yes I know I will get a lot of hate for this).
A good set of tire and a Practical Lift kit will do quite a bit!! I myself went with the Old Man EMU lift kit by ARB. I also have 285/70-17 Firestone Destination XT'S on stock wheels with no spacers. The overall handeling has improved with the suspension and the OffRoad capabilities are great!! Want to tow? Well you still can tow at factory towing capacity too!!
Here are some pictures of the truck with the tires and lift
sts90
sts90
Theo
Ponchatoual, La
AzScorpion and Frenchy,
Your pictures show about the extent of what I want to do currently. I have done a fair about of traveling by 2wd truck in places I should not have gone before my family. I am looking to do trails with my boys to see what is off the pavement. Maybe some camping as they get older because the boss likes her A/C. I am thinking the Ford fox 2.0. The I will go one size up in tires once these wear out. I picked the truck up used with 7,600 miles at a Subaru Dealership, So the tires will be a minute. I was told to replace the running boards with rock sliders to avoid body damage, that worth it?
Your pictures show about the extent of what I want to do currently. I have done a fair about of traveling by 2wd truck in places I should not have gone before my family. I am looking to do trails with my boys to see what is off the pavement. Maybe some camping as they get older because the boss likes her A/C. I am thinking the Ford fox 2.0. The I will go one size up in tires once these wear out. I picked the truck up used with 7,600 miles at a Subaru Dealership, So the tires with be a minute.
Yes they are well worth it. If mine didn't already come with the factory steps that's the route I would've gone. I don't care for the steps and have scraped mine many times and if I weren't getting a Bronco next year I would replace them with sliders.
Your pictures show about the extent of what I want to do currently. I have done a fair about of traveling by 2wd truck in places I should not have gone before my family. I am looking to do trails with my boys to see what is off the pavement. Maybe some camping as they get older because the boss likes her A/C. I am thinking the Ford fox 2.0. The I will go one size up in tires once these wear out. I picked the truck up used with 7,600 miles at a Subaru Dealership, So the tires with be a minute. I was told to replace the running boards with rock sliders to avoid body damage, that worth it?
Depending on the trail you may or may not need it. For me I have not needed it. Mostly for the fact that i have a good amount pf lift up front and in the back. Effective lift on my truck is 4 inchs front and 3 inches rear. And with that I have yet to hit much if anything.
sts90
sts90
Theo
Ponchatoual, La
Which one's do you think are worth it? I like the ones with flare out past cab for a step to access my tool box better.
Bludrok
Acampo, California
www.ranger5g.com
If you are doing any rock crawling, yes absolutely. If not, wont make a difference.
To your first question, you asked what I would do.......I tend to go overboard, see my build page. I started installing the Bumper/winch/light bar and pods tonight.
However, if you are just looking at dirt roads and the like, I dont even think you need to do anything. Having the FX4 gives you a rear locker, which is probably more than adequate.
RoadBoss
Travis
Lakewood, CO
www.TJAoutfitters.com
Rock sliders are great for peace of mind on the trail. Not necessary at all, and you can do some pretty rough trails without having to worry about it, but certainly comforting to have when you do get to some rocky sections.
Otherwise, I've been running on the just Eibach front shocks/level at the 2.25" setting (and stock springs) and it has been more than capable on any kind of terrain I've found in Colorado.
After almost 2 years I am finally changing out the rear shocks as well, and just installed an add-a-leaf to make up for all the weight I've added and get a little extra height/clearance.
Also, tires. They are the #1 most important thing to change out. Stick with the 32-33" range, and don't go too wide (I prefer real skinny, but certainly don't go wider than 285).
For reference, I did this "difficult" rated trail, with just a 2" spacer level kit and 32" tires (235/85r16) and no rock sliders or traction control. I would definitely not do a spacer level kit again, but at the time there weren't many options.
slowmachine
New Hampshire
Why not drive it as-is and see how the stock suspension works for your location and driving style? If it needs new tires, buy some. I think that the most important off-road skill is knowing when to get out of the vehicle and walk. Off-road with kids means the most important thing is to get home in the same vehicle you left with. Over time, you may find that some suspension mods may get you just a little bit farther, but no vehicle can match a pair of hiking boots for getting past obstacles.
Charley
Next Door
2024 Bronco Badlands Hot Pepper
1. Tires, the Hankooks did not work well for me. Plenty of different All terrain options. I went with 32 inch BFG KO2
2. Lift? maybe. Just depends on what your plans are. I went with the Ford 2 inch level kit, (2019-2021 RANGER FOX "TUNED BY FORD PERFORMANCE" OFF-ROAD SUSPENSION LEVELING KIT, M 18000-RA)
3. Rock rails. Once again, If you think you are headed toward trails with narrow widths and rocks, then yes. I have the shrockworks and they work. It would have been nice to have a set with the kick outs when I had the RTT mounted.
As mentioned by others, many a Ranger have been off road stock with very few problems.
With an FX4 model, you already have some basic under body skid plates. And I believe a stock ranger did the big 3 Colorado passes, Black Bear, Ophir and Imogene.
Edited to correct that I leveled, not lifted. Though to level I had to lift. Such a quandry.
2. Lift? maybe. Just depends on what your plans are. I went with the Ford 2 inch.
Yeah..... Soooooo Ford does not have a lift kit available in thier parts accessories for the Ranger. Now they do offer a leveling kit!!
Skoth
Utah
2021 Ford Ranger XLT
Tires is the first thing to do. A small piece of vegetation (a weed) punctured the sidewall of one of my factory Hankook tires a week after I bought it. I was slowly driving through a grassy field. Yes, that's all it took. My go to truck tire is the Falken Wildpeak AT3W. They work in snow, mud, rock and on the highway. They also self clean very well. I went with 10plys because I drive over a lot of sharp granite rock when I'm offroading
