Antenna stanchion/base alternatives to shark fin
Alistair
2020 Ranger XL SuperCab STX
Hi guys-
I have a camper shell that overhangs the cab a bit and was scraping the shark fin. In order to lower the antenna height I took a chance on replacing it with this antenna stanchion for a Ford Escape.
It was a good fit for plugging the hole in the roof, but the connectors were not a good fit for the connectors in my Ranger.
I'm attaching photos of the antenna I removed from my truck. Can any of you suggest a replacement for the shark fin that has the same connectors but has a similar profile to the Ford Escape antenna linked above?
Thanks!
Rinn69
N. Central Iowa
Retired USAF MSgt
If you scroll down to the bottom of this page, there are 4 threads about this same subject :) :thumbsup:
Alistair
Yup, I've read them all. Two are about the whip antenna, which comes off by hand. Two are about removing the existing antenna base, which I've already done thanks in part to those threads.
One of those threads starts with the same question I have-- what is a low profile replacement for the antenna base-- but for some reason all the replies in that thread are whip antenna recommendations.
I've got the old antenna out and I replaced it with something that is really just a plug. Now I'm looking for a replacement antenna base that will connect properly.
I can put this post somewhere else if necessary, but my question isn't covered in those threads and isn't really the same question, aside from the fact that it's antenna related.
Let me know if you have ideas that aren't covered elsewhere.
Fawnbuster
Indiana
Retired 34 years as LEO
is the angle less than our oem mount? It would be nice if while you had the new one off if there was a set screw that allows you to tilt the mast down, that would solve a ton of issues.
Alistair
Not sure exactly what you mean, but the whole antenna is significantly shorter than the stock Ranger antenna. I can take some measurements if you need them, but it's about half as tall as the stock version. The Escape antenna doesn't really have a shark fin, it's just a round lump.
There's nothing to adjust on the stock antenna once it's off. It's a solid block of metal and plastic.
Apolakay
Pablo
Montreal
Ford ranger lariat 2019
Medical
Hi guys-
Thanks!
Hi sir how did u remove the base antenna?I accidentally backed up in my garage and it came off from the base.thanks to the 3 inch lift that I forgot it was there all along.
Alistair
Apolakay
Pablo
Montreal
Medical
Thanks sir,I dented I bit the roof but hopefully I could push it back once I remove the headliner.wish me luck
