New Fabtech Intrusion Beams pics
KevinG
kevin
nevada
2020 Ranger XLT
Business owner
Got them in today. They are seriously strong and Fabtech quality. Pic shows the difference between oem bar and Fabtech.
Will get them installed in the next day or so with pictures.
cfhgarza
Ohio
2020 Magnetic XLT 301A
Press and weld set-up
These are to allow for bigger tires?
SPEEDBUILT
Zak
SacTown
2020 Ford Ranger Lariat FX4
Strength Coach
About to tackle this job, how hard was it to remove the factory ones?
Jms81661
Las Vegas, NV
2020 XLT Ranger Sport
Truck Driver
I assume you're going for 285's/33's then? I'll be watching cuz mine are on there way and I really need to get new tires. Tore up the sidewalls on stocks on the trails yesterday.
Lots of pokey stabby rocks out here.
Bigger tires, yes.
Also, for when wheel spacers or low/negative offset wheels are used to “push” the tire further out toward the fender.
When your wheels are turned, the tires will be pushed toward the crash bars, often making contact.
xABNINx
Roderick
Anaheim, ca
Does the bumper have to be removed? If so, was it easy enough to remove bumper?
RCMUSTANG
Ray
Los Angeles
2017 Fusion 1995 Ranger
What sucks is I only need extra room on the rears. Not going to get a set just for the rears. I'm gonna notch them out with my plasma tomorrow and box it back with the cut off piece.
KevinG
KevinG
kevin
nevada
2020 Ranger XLT
Business owner
They are tough cutting for sure. Once they are out it is easy. I used a jig saw with carbide tipped blades. You will go through a few of them fyi.
TN Ranger
2020 Ford Ranger
Electricain
You had to cut to remove old ones but did new ones just slide into place or did you have to loosen bumper or anything?
