303 GRAPHENE NANO SPRAY COATING
Islander
Turks & Caicos Islands
RAM 1500, Toyota 4Runner
For you guys with experience with this, is washing & clay bar a sufficient prep before applying 303?
Thanks.
If you're happy with your paint (I.e. swirls, scratches) then other than polishing the only thing you might do depending on where you live is a quick spray down and rinse after washing with an Iron Remover (I use Adam's Iron Remover). That said I did it once over a year ago to remove brake dust but where I live there is little air pollution/fallout so I have not needed to do it again.
Muffin1
NJ
Yes the paint is in great shape I’ve previously clayed and waxed with the old school stuff so I’ve maintained it pretty well, this is going to be the first time using this type. I purchased it on the recommendations of users here, so excited to see the results
Muffin1
NJ
Rob, It is sufficient but they (303) state that you can apply the Graphene over any other manufactures product. But to get the best results you should remove the old wax and start fresh. I use a product called Paint prep which you just spray on and wipe off but there's many others out there that work just as well. This way the Graphene will give you 1 year of protection and you won't have another product breaking down under it.
https://www.autogeek.net/optimum-paint-prep.html
Ahh got it, thanks for the tips.
Motorpsychology
Prescott, WI
Vagabond
No worries Phil one day you might try a Ranger and find out how great they are. lol
I love detailing so it's fun to talk with others who do too. I haven't yet tried it as a drying aid but have heard others have had good results with it that way too. It's so hot and dry here in AZ I'll be working harder trying to spray it on, wipe it in and then keep the rest of the truck from drying on me. The detailer is just like the Graphene Nano spray a little goes far and gives you great results.
...Available in Regular Size,
And Dave Size,
BettaRanga
NC
2021 Screw 4x4 Lariat 501a Blk App Carbonized Gray
I decided to get a bottle and try it out. I'm pleased, it was very easy to use. I used it on everything, paint, trim, moldings and glass. Everything feels slick! My Ranger makes this product look good! Did I say that right? Ha-Ha
I want to know where all the stuff that is supposed to go in your garage is located! So empty in there! :crackup:
Islander
That's only a months supple Chris. ?
Dave:
Do you use 303 Graphene on matte black plastics? If so, how does it hold up in terms of keeping them from fading?
It looks like you have black running boards but wondered if you use it on those.
I have been using a VRT product for black plastics for UV protection ...but applied 303 Graohene a couple months ago to my running boards...so far I think it's working OK...but kinda hard to tell.
imapseudonym
2021 APG Ranger Lariot
I just picked up a bottle of this stuff. Still need to find time to actually thoroughly clean and coat the car. But based on everything I see here it looks great!
Dave:
Phil, Yes I use it on my running boards and I pretty much use it on everything on the exterior of the truck except the plastic on the rear bumper and the tops of the bed rails. The Ranger has a matte black wrap between the front and rear doors and I've always used it there and it's held up great, no fading at all. That's why I like this stuff so much as you can basically hit and protect everything without having to change products.
Islander
That's awesome and good to know !
outdoorphotog
Ian
Healdsburg, CA
2019 Lincoln Navigator L
Limo Driver
I put some on my new to me Lincoln Navigator, its amazing. Was holding up great when I was handwashing. Then when I brought to a modern-ish carwash, it seems to be coming off the rear a bit. Maybe needs another application.
Dave is winning when finding 303 Graphene tho
Mostly Harmless
New York
2021 CG Tremor
I think I may take back my recommendation for using the detailing spray as a lubricant when drying the car. The other day when I was using it on my GF's darker car it was streaking a lot, something that is a bit harder to notice on my truck. Once her car was dry I just when over it again with the detailing spray and it came out just fine, but it was additional work.
Just curious what everyone else is using for a lubricant when drying? I don't want to put another layer of a different product between the 303 and the 303 detailer.
I haven't tried using the Detailer spray while wet. I always just dry with a drying towel then apply the spray after and that method has worked out the best. With the 303 you're supposed to use little product so I'm guess while wet it's harder to tell how much you're actually using and also you're moving it around more while it's wet and it's clumping up in areas causing it to streak.
These work really good for drying. I ended up cutting mine in half because it's to big and absorbed a lot of water and was a pain to use. I had my girlfriend sew the ends and now it's much easier.
https://www.goldeagle.com/product/303-waffle-weave-drying-towel/
Mostly Harmless
New York
2021 CG Tremor
I use the same the towels, they work great. I am going back to my old method and use the detailing spray as touch up every few washes. The 303 is still beading after months of use.
