303 GRAPHENE NANO SPRAY COATING
Kodiacnb
Robert
East Coast, Canada
2021 Ford Ranger XLT Super cab
Retired Postal Worker
I have a leaf blower I use after a wash, to dry, and use the waffle towel to pick up the slack. With the leaf blower it drys pretty fast (5 min) and it eliminates water spots.
Muffin1
NJ
Yea mentioning water spots i guess i was misunderstanding ceramic coatings, after a brief shower i checked out the beads on my car (not the Ranger) i then wanted to see if there was any 'sheeting' action so i used the garden hose most of the water rolled of there were some beads large/small left, i then was distracted and went inside my house later i came out to see the grayish rings left behind from the dried droplets, i then quickly soaped it up and rinsed most of the spots were gone,
some you could still see so i used Mothers quick detailer and that removed any 'shadows' of them.
So the 303 acted as a shield to protect the clear from damage, i was under (wrongly) that the ceramic coat was some sort of force field shield:LOL:
I don't know a lot about ceramics and there's so many of them out there now. I know with the Graphene you can still get some water spots but they'll come right out.
I was at a customers house last June and their sprinklers went off around 8:00am blasting the drivers side of my truck. We have really hard water so the whole side had spots and it sat in 110 degree heat all day. I went home and hit it with the Graphene Detailer and they came right out easily. It'll act as a barrier on the surface so the water won't etch into the clear coat, if you leave it long enough I'm sure it could.
RangerVol
TN
'22 Ranger XLT
Is it ok to spray 303 graphene on headlights/tail lights, would you use detailer instead or something else?
oh what about wheels? mine are black
Yes you can. I use it on all those and everything else on the exterior except the tonneau cover, plastic bed rail caps and the plastic on the rear bumper. For those I use the 303 Aerospace Protectant.
Oh, I also use the Graphene on the wiper blades and the wiper arms.
Islander
Turks & Caicos Islands
RAM 1500, Toyota 4Runner
Absolutely...I have been using 303 Graphene on headlights, taillights and all windows too and it works great.
I also have black painted wheels and apply it to rims too...although does not seem to last quite as long likely due to repeated use of wheel cleaner spray....but still produces good results.
RangerVol
TN
'22 Ranger XLT
First...Does a 303 Logo pop up on your phone whenever it's mentioned HAHAH
Got a friend that has a case of the UV spray and Tonneau cover spray given to him by a vendor and he's going to give me a bottle of each. I have some graphene spray that's just waiting to be used... need to pick up some detailer for those days that birds decide they wanna poop on my ride.... LOL
RangerVol
TN
'22 Ranger XLT
Thanks...I guess it helps with water beading on the windows...I'll have to give that a try too.
My instant radar goes off when 303 is mentioned. lol
If you haven't already read the first couple posts on this thread and also check out my write up on the detailer here. It's even easier to use than the Graphene Nano spray.
Motorpsychology
Prescott, WI
Vagabond
Put it on very thin, as it can leave a haze after wiping it off if you apply it too thick. If that happens, use Windex or comparable to remove it then reapply the 303.
