rangerdanger
- Joined
- Oct 9, 2018
- Threads
- 194
- Messages
- 3,489
- Reaction score
- 2,635
- Location
- SF Bay Area
- Vehicle(s)
- 2019 Ford Ranger SuperCrew XLT FX4
- Vehicle Showcase
- 1
- Thread starter
- #76
Do you know if that was with the new 5 star tune or just higher octane fuel as the post is titled?
I believe it’s the 93 performance tune.Do you know if that was with the new 5 star tune or just higher octane fuel as the post is titled?
Gotta say, the speed pickup was super impressive.
Video working fine for me still, and to answer the question above on fuel, yes you can feel a difference with 93. Mostly in your wallet, but there's some improvement on the butt dyno. It's already spinning tires and using traction control with 87, it might go from 40-60 faster though.The video isn't working and I can't seem to find it on their Facebook page. I wonder if they took it down.
It’s on the road and not the dyno. You can see slight steering adjustments being made which would never be done on the dyno and the rolling weight of the ranger in crew cab 4wd is right around 4550 lbs. 6050 is the gross weight if loaded.Do you know if that was with the new 5 star tune or just higher octane fuel as the post is titled?
Edit: I was thinking about it and I wonder if the video was the truck on a Dyno or on the road. The quick acceleration between gears would be a huge difference. IF it was on the road, and you're pushing the over 6,000 lb truck, that's awfully impressive. If on a Dyno different story.
You sir are respectfully incorrect. All of the ecoboost sensors add timing and pull fuel based on information from their multiple knock sensors. This is well known at this point, and has been around for quite a long time.Octane is not a measure of quality or power of the fuel. It is a measure of how fast the fuel burns. High octane burns slower which is what a high compression engine needs. Turbo or not doesn't make a difference. (93 burns slower than 87 to keep hot parts from pre-igniting that causes pinging.. That's it.The engine HAS to be TUNED for the octane used.
If the stock tuning is used there is no benefit to using 93 at all. Nada...Maybe a Placebo effect.
It’s possible that some issue like carbon build up or a clogged EGR passage may cause the engine to start knocking with 87 octane. Then the knock sensor picks this up and causes the engine computer to retard the timing, which can reduce the MPG.
Tune the engine for the fuel used. Otherwise, there is zero benefit to higher octane fuel
This is entirely more pronounced in hot climates, in the winter where temps are always pretty low, you will see less gain. On a 100F degree day, baking on blacktop the fuel will make a big difference.Ecoboost uses OAR (Octane Adjust Ratio) for timing adjustments for the octane used. Uses the knock sensors to either add or subtract timing. The ECM will continue to add timing until knock is detected and then will back off till the knock is removed. The 2.7L and 3.5L Ecoboost rated for 87 octane in the F150 will see a gain of around 20+ HP when using premium fuel.
https://www.cobbtuning.com/ford-ecoboost-and-the-octane-adjust-ratio-monitor/
