265/70/18 and Ford Performance Tune
pdbwest
North Vancouver
2020 Ford Ranger
Anyone know if the FP tune will allow you to adjust for 265/70/18's? Seems to be conflicting info on this?
Thanks,
I believe the Ford Performance programmer is based on the Livernois Mycalibrator, which I am pretty sure allows for such adjustment.
dondonbabyraptor
Brandon
San Diego
2020 Ford Ranger Lariat
I/O Psych MSc student
Not really sure and a bit too lazy to dive deep into the threads about this. However, if you display your speed on the tuner it shows your actual speed, just a bit annoying to look at it but it gives you a relative gauge on how much faster your tires are going now vs what it used to be. This at least gives you a baseline comparison for speedometer vs actual speed.
MXGOLF
Sales / Photographer
You adjust the truck with Forscan and the new tire size. I don't think tunes are set up for different size tires. Forscan. I may be wrong???
Hey Mark,
Some of the tunes include tire calibration, many do not. There is also a stand-alone tire calibration device (HyperTech?). If the FP tune doesn’t have it, Paul can always use Forscan or pay the Ford dealership to change it for him.
pdbwest
pdbwest
North Vancouver
2020 Ford Ranger
Hey Mark,
Gotcha....makes sense. Thanks All!
This just in…. :(
Ford Performance calibration for 2019-2022 Ranger EcoBoost. The Ford Performance engineered performance calibration is a 50 state legal calibration for your Ford Ranger that increases power and improves performance throughout the RPM range. The 2022 calibration is available for non-California vehicles.
  • 50 state legal - C.A.R.B. EO#: D-431-4 (2019-2021 vehicles)
  • 2022 available for non-California vehicles
  • Ford Performance engineered and dyno tested
  • Improved drivability and throttle response throughout RPM range
  • Optimized shift schedule
  • Horsepower gain: 45 HP @ 4,500 RPM
  • Torque gain: 60 lb.-ft. @ 2,500 RPM
  • For U.S. and Canadian vehicles
  • Comes with Ford Performance 3yr/36k mile warranty from new vehicle in-service when installed by a Ford dealer or ASE/Red Seal certified technician
  • Tire size configurable up to a maximum diameter equivalent to a 265/70R17 tire as recommended with the M-18000-R Ranger Off-Road Suspension Leveling Kit
  • Premium fuel - 91 octane or higher is required
  • Includes Ford Performance Pro Cal 4 calibration delivery tool M-12655-F
  • Includes Ford Performance high-flow K&N® air filter
  • Optimized for trailer towing
***Calibration and ProCal 4 tool are VIN locked. Please contact the Tech Line with additional questions***
***NOTE*** ProCal 4 software only available for Windows 7 or greater. Will NOT work with Windows 10 in "S Mode".
***NOTE*** ProCal 4 tool receives periodic firmware updates for greater usability and additional features. Please connect tool to PC periodically to receive the updates automatically.
Ranger X3
Matthew
Sedona AZ
2019 Ranger Supercab Lariat FX4
Tap- diagnostics & tools, tire/ gear adjust, tap tire and type in new revolution per mile number 618 (Google search) then follow on screen prompts.
1pt21gw
West Coast
Ye' Ole Traveler
My XLT's stock tires were a bit off on actual speed and after adding bigger tires - 32" / 275-65-18 , I used the Ford Performance tune and it's little box to adjust my revs.
Ended up being pretty close to what it was already set at. Adjusted a couple times to get it accurate as the math on tire sizes is different between brands and what the internet says to what they actually are. Use a GPS tracker to help you, a phone or bike computer or a gps unit to dial it in,
Bonus... I got a happy transmission and a snappy truck!
LoneRNGR
Lubbock, Texas
2020 Ford Ranger XLT
Systems Engineer
Yes. You will be able to adjust it using the programmer that comes with the tune. In fact you don't even have to have the tune installed to make this change. You will adjust using Revolutions Per Mile (Revs/Mile).
On my truck, I looked up my Revs/Mile for my tires on Tiresize.com by looking up my brand and size. I entered this value (example 637). I verified the speed using a GPS. I found it was slightly off and I adjusted (to 633) and it is perfect.
Bravohook
Addame
Victor
2021 Ranger XLT FX4
Sheepdog
I used my FPP Tuner to calibrate my speedo ro my 285/70's Tire rack.com has the rpm's listed for most tires on their webpage. Their page got me close and was able to fine tune it to get me spot on.
Philvarah
Phillip
Arvada, CO
2022 Ford Ranger XLT Splash
Sales
Does the Ford Performance Tune take into consideration any other mods like Cat Exhaust... CAI... Downpipe etc... Or do you just add the Ford tune and go... vs other aftermarket performance tune company offerings that can be more specific?
jflogerzi
Moreno Valley, CA
Factory config only. Catback will not affect things but a CAI or Downpipe will mess with AFR's and tune is not setup for that. I would get a custom tune with those mods.
Superspirit
earth
22 ranger
No adjustments on the Ford tune. If you want that you'll need a custom tune. I and several others have been very satisfied with Torrie @unleashed tuning
