2021 Transmission shifting weird
2TurboRanger
Jack
Oakley, Comiefornia
Wife 21 Ranger XLT 2.3 2x4 Mine 26 Ranger Raptor
Retired Mechanic
2021 Ranger XLT Transmission shifting weird and a Wrench light came on
Turned off the motor and restarted and it went away it has 45k on it .
its' past the 36 / 3 year warranty
RangerBill
PA
Scan for DTC codes.
DaveT
Scottsdale, AZ
2023 XLT Ranger Tremor
With this information, no one here can tell your more than your Ford dealer, but a search of this forum will tell you that pre-2023 models were prone to transmission issues.
RangerBill
PA
There is no DTC codes
If the wrench light came on, a DTC code should be stored. I would recommend getting Forscan and an adaptor to check for codes. Many cheaper scanners only read powertrain codes.
2TurboRanger
2TurboRanger
Jack
Oakley, Comiefornia
Retired Mechanic
I have Forscan . I have been resetting adaptive learning I guess I can do it again
Stevedbvik1
2022 Ranger Tremor XLT
Transmission is covered under the 5yr/60K powertrain warranty
if it does it again - (Wrench) light - do no cycle the key off, until you scan for codes, this way you should be able to see the code before it self resets
2TurboRanger
2TurboRanger
Jack
Oakley, Comiefornia
Retired Mechanic
The rebuild on mine (2019) would have cost $6300.00 if I had to pay for it. It was covered under the extended warranty
This is new not rebuilt 3 year unlimited parts and labor warranty and I install it.
I could get a rebuilt $4838 + $150.00 for shipping
