2021 Transmission shifting weird
2TurboRanger
Jack
Oakley, Comiefornia
21 Ranger XLT 2.3 2x4 Wife Mine 26 Ranger Raptor
Retired Mechanic
2021 Ranger XLT Transmission shifting weird and a Wrench light came on
Turned off the motor and restarted and it went away it has 45k on it .
its' past the 36 / 3 year warranty
RangerBill
Scan for DTC codes.
DaveT
Scottsdale, AZ
2023 XLT Ranger Tremor
With this information, no one here can tell your more than your Ford dealer, but a search of this forum will tell you that pre-2023 models were prone to transmission issues.
RangerBill
There is no DTC codes
If the wrench light came on, a DTC code should be stored. I would recommend getting Forscan and an adaptor to check for codes. Many cheaper scanners only read powertrain codes.
2TurboRanger
2TurboRanger
Jack
Oakley, Comiefornia
Retired Mechanic
I have Forscan . I have been resetting adaptive learning I guess I can do it again
Stevedbvik1
2022 Ranger Tremor XLT
Transmission is covered under the 5yr/60K powertrain warranty
if it does it again - (Wrench) light - do no cycle the key off, until you scan for codes, this way you should be able to see the code before it self resets
