seanellaz
- First Name
- Sean
- Joined
- Nov 14, 2020
- Threads
- 3
- Messages
- 338
- Reaction score
- 460
- Location
- Tucson, AZ
- Vehicle(s)
- 2020 Ford Ranger XLT CrewCab Fx4
- Occupation
- Healthcare
- Vehicle Showcase
- 1
https://media.ford.com/content/dam/...roduct/2020/ranger/2020-Ranger-Tech-Specs.pdfAt 22k with a Roush tune, I have noticed since I went from the OEM sport wheel 17" tires to the Goodyear Ultraterrains 265/70/17, the transmission shift points in "D" seem pretty awful and the transmission gets easily confused. Around 50mph, it will go from 9th gear to 10th, almost everytime i do a small gas pedal touch. 10th feels like its lugging at 1,400rpms or so at 50mph. Also going up hills in "D" it just seems to try and stay in the highest gear possible almost lugging up hill, its pretty bad. "S" seems to improve the uphill and flat land behavior, but on the steep downhills "S" causes 4,000rpm which just sounds bad, and ill have to shift to "D" to keep the revs down on a downhill.
The only other thing is I recently took a new job with almost 6000 ft of combined elevation gain in the morning (over 3 mountain ranges), and quite a bit less on the way back.
Recently I did a trans flush with Mercon ULV, it is back up to the correct level which is 4-5 at 207F-215F. I dont know if its better or worse since I have done that but feels about the same.
Anyone had similar issues in "D" they were able to resolve?
If I understand the specs correctly, all gears above 7th are "Overdrive", so 10th gear ( 0.636:1 ) is pretty tall. Ford seems to have programed the shift points in D to minimize fuel consumption and engine wear. My truck has 3" lift and 295/70 17 tires. @ Constant speed, interstate, flat road, 10th gear is fine. Uphill grades, headwinds, need for acceleration all need downshift which does not happen until I squash the pedal. I am a control freak so sometimes put it in Sport mode then manually shift to keep RPM in higher range, 2K+. Trailer Tow mode will do this for you, and also hold in lower gear when going downhill to engine brake, downshifts more when decelerating to engine brake also. If the Roush Tune is behind your trouble, I'd take it back to dealer for looksee.
