10 Speed fluid and filter change
GreyAreaRanger
GreyAreaRanger
Houston
2019 Ford Ranger XLT
Surgical Nurse
I should've looked at the sticky first.
Item #28: Removed differential drain plug.
That must've saved them in the tens of cents on each truck :mad:
For some reason my last reply went through late and you appear to have found the same stickie
pbethel
Patrick
kingman az
It's better to pull the cover and clean all the wear debris out of the dif when you change fluid.
Otherwise all that crap continues to circulate through the gears and bearings.
Wytchdctr
Doug P.
Westside Htown, Texas
2021 XLT
Retired Military/HR Manager
The diff drain plug isn't gone, just relocated.
Unless this was another "cost down" casualty.
Is this missing on the later trucks?
I was annoyed about the missing plug until I thought about it like that. Also the gasket is cheap enough.
ctechbob
Shawn
2020 Ranger XL/FX2/STX
Adult Daycare
GM Spent millions upon millions of dollars in warranty claims to save $2 on a torque converter. :)
Living The Dream
And the guy who came up with the $2 savings idea probably got a bonus and employee of the month ?
Cmar
Cam
Australia
Ford Ranger PX
Medical Scientist
I've never been a fan of Salisbury diffs. Every single one I've owned has always whined.
BS67
Brian
Nebraska
2022 Ranger XLT
Yep, ridiculous to eliminate it.....would be real handy to have one instead of removing the cover!
