Transmission fluid change but no filter change?
Old NaCl
Greg
2019 XLT Ranger 2X4
Mechanical Designer
A dirty filter, filters better than a new one.
Easy fluid swap out (without filter)......
!. Buy a tranny Fitzstick from Mike.
2. Install the Fitzstick.
3. Buy several cases of proper tranny fluid, either Ford or Valvoline (cheaper when on sale at NAPA Auto)
4. Buy a $16-$20 buck 12 volt transfer pump from Amazon
5 thru 50. Every 10-12 thousand miles pump fluid from tranny pan ...easy-peasy with Fitzstick and pump. Should be able to pump 6-7 quarts out, and replace with new. Repeat every 10-12 thousand miles and you will be constantly running fresh fluid in your tranny.
Pump and Fitzstick will also make it much easier and less messy when you decide to drop pan and change filter.
Zims4x4
2022 Ford Ranger XLT Forged Green
Do you have the part number of the pump from Amazon?
Zims4x4
Thank you all for everyone's assistance , picked up a Fitzstick from Mike ( Great Guy ), and recommended pump , made for an a lot easier transmission fluid change.
carnut122
Tim
GA
1953 F100, 2008 Saturn Sky, 2019 Ford Ranger
Until it no longer passes the required amount of fluid.
Reminds of the time I was working on a big old International tractor. Customer was complaining about loss of power. He even tried things like turning up the fuel (diesel). All that did was make more black smoke. I checked the air filter, must have been about a half acre worth of dirt in it. I still can't believe he spent all that time and effort and never thought to check the filter.
