- Joined
- Aug 24, 2022
- Threads
- 28
- Messages
- 4,470
- Reaction score
- 8,545
- Location
- Midwest - KS
- Vehicle(s)
- 2022 Ranger Lariat-Super Crew, Cactus Gray
- Occupation
- Aircraft Tech
Being that there is (1) thing missing from all diagrams, and that is input (Temp -Selected)
I think I have how the system works as this will account for your control test failing. at the Temp/Humidity sensor
The 5-Volt reference, will always be present and not change (5-Volts)
The signal return side- will be the differential varied voltage from all factors (Controlling) (Temp Sensors, Humidity/Temp Sensor, and the unseen (Temp Selection, Sunload Sensor, Ambient Temp Sensor) accounts and controls all door positions.
All of the unseen inputs are dealt with internally of the FCIM, and then tied into the actual external temp sensors that are viewable on the wiring diagrams.
Signal Return = (Voltage difference of the 5-Volt Voltage) and it is the (actual temp control / door control)
Thus, it is varying the ground return of the 5-Volt Reference by the Thermistor's and Capacitance Sensor and (Internal Inputs) from FCIM
The internal inputs in the FCIM also ties into the 5-Minute timer theory as the FCIM would have to be the (Control) for that timer.
The Timer control is not documented anywhere I can find, but we know some kind of timer is there or as you said, with high humidity readings in the truck, the Inlet Door should have stayed open and not timed out and commanded back to close by the FCIM
The key factor to look at would be the difference between Max AC and AC and all other selectable settings this would show the controlling (timer) as by documentation the Max AC setting keeps the Recert active, and the door closed. (So, in theory this would disable that 5-Minute timer)
But we can't see that specific, documentation, diagram on the internal control for that function.
Is this how you see it?
