Wireless charging and fuse questions from a newb!!
iclimb17
T
Simi Valley, Ca
2022 Ford Ranger Lariat FX4
Area IT Manager
Howdy folks.
2022 Ranger Lariat FX4 owner.
I just received Dirks add in bracket. Wow. Fits amazing.
Im using the AAwireless for android wireless.
Ok, onto the main issue. Charging pads seems to get warm and I need to ask all you experts if Im doing this correctly.
Did I wire it correctly?
1. I have a 5a on top and a 10a on the bottom on the fuse tap..
2. I picked fuse spot 35 as its a unused 5a - is this correct? Or do I need to pick a 15a spot? Do you suggest a different spot?
3. The black wire - just wrap around a spare metal bolt?
4. Charging seems to work but it seems to stop randomly as well.
5. #35 spot is not powered by ignition which seems right. Just not sure of the 5a
Just want to make sure Im doing this all right and I need some help from all you experts. Oh and Dirk has been super helpful!!
Thanks everyone.
SigOris
Greenwood Maine
Retired DoD EE
Howdy folks.
Im using the AAwireless for android wireless - pain in the butt to get going. Loves to keep disconnecting randomly. Tried all the things I've researched. Pass through, dongle mode, battery saver, etc.... Its acting a bit better now. Time will tell.
Thanks everyone.
From their website:
The power consumption of AAWireless is between 90mA and 330mA, so unless you leave it for well over 2 weeks in the car, without starting the car, this should not be a problem.
so worse case appears to be 0.3 A
