Help with Wireless charging setup
Mostly Harmless
New York
2021 CG Tremor
Just recently installed DirkM wireless charger and I am having some issues with it charging my phone. I installed it using this converter: https://www.amazon.com/gp/product/B0918CR35N/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=
I am trying to charge a Pixel 6 Pro with the unit. I think the converter might be bad though looking on Amazon they all look the same. Any recommendations on a better converter? I know the pad works because I hooked it up inside with a power brick. Not sure if maybe this setup just won't work with my phone.
Dr3wDrop
Andrew
OHIO
2021 Lariat Tremor
Try plugging the phone directly into the USB on the converter to narrow down the issue.
Where did you get the power and hook up the ground wire?
Mostly Harmless
Mostly Harmless
New York
2021 CG Tremor
Dr3wDrop
Andrew
OHIO
2021 Lariat Tremor
The fuse tap i bought from amazon had too much plastic at the base to get it to fully seat in the panel. I ended up taking a razor blade and shaved the plastic down to get it to fit. Check to see if its fully seated first. What fuse location did you use?
Mostly Harmless
Mostly Harmless
New York
2021 CG Tremor
Thanks for the help guys. I ended up plugging a wireless charger from the house into the converter and it worked just fine so it has to be the mat, will have to try and find a better quality one that somewhat fits.
