Why is my truck SO HIGH
xplorre
xplorre
Various parts of California
2021 XLT FX4
Got an alignment done, it seems to have settled well. It was crazy that I got 1.75" of lift between measuring it with the OME and then again as soon as I sat it back on the ground with the 5100s.
I'm assuming the ome springs had settled in.
On another note, with the icon uca's, caster is at 4.5°, equally on both sides. Anybody else find this strange?
Grandaccess
Binghamton, N.Y
Computer Consultant
Hahaha, I'm on the cusp at 41. In my defense, I measured before and after, expecting a .1" lift and it was legitimately almost 2" taller 👀
I panicked before taking it out for a drive and parking it level. Getting an alignment right now, hopefully it's within spec since it looks great
I have noticed the first few miles after being on a lift it looks like the front is taller too?
Ranger Pete
Peter
Cape Coral FL
2020 Ranger 4X2
How can I tell if my recently purchased 2020 XL is lifted? It seems a little high to me. Is there a measurement that can be taking like ground to high point of the of the wheel well?
dozxab
Prescott AZ
My XLT FX4 with Hankook 265/65/R17 tires was 35.5" ground to center of the wheel well arch on the front and 38.5" on the rear. I went up 3/4" in the front and middle of center cap to the same location is now 22 3/8" front, 23 1/2" rear. That should give you a good idea.
Ranger Pete
Peter
Cape Coral FL
2020 Ranger 4X2
Thanks, My front is 37 1/4" and the rear is 37 3/4" I have 265/70 17 tires so that gives me + 1/2". All stock shocks as far as I can tell.
dozxab
Prescott AZ
2" spacer lift?
Dereku
Chicagoland Area
Brand new oem springs? They need to settle a bit, the 5100s are rock hard, like back when you old guys were 18. A few thousand miles will soften them up.
Superspirit
earth
22 ranger
Not on the 2.5 setting. That's why I'm going to a 3.5 lift to set the 5100s back down and soften the ride.
They rode great at 1.2, but when I bumped them to 2.5 they got stiff and stayed that way for 10k miles.
Dereku
Chicagoland Area
I did the first notch, 0.8 or something. Mine softened up. The extra tension probably doesn’t help and A arm angle too.
xplorre
xplorre
2021 XLT FX4
Original OEM springs, I had maybe 20,000 mi on them when I took them off for the ome setup. I actually love the way the thing rides. The front is pretty level with the rear though now, which is not my jam. Makes me wonder if the ome standard rear springs have settled. Might be time for a little shackle lift in the back.
seanellaz
Sean
Tucson, AZ
Healthcare
Greetings,
Wore out my OME suspension and just finished installing 5100s (with the stock springs of course) and icon ucas.
I have the 5100 set at the 2.5 in Mark, now installed. The truck sits a solid 2 in higher than the measurements I took before starting this job. 👀
Help
Very nice steup. Low key, easy on the eyes.
seanellaz
Sean
Tucson, AZ
Healthcare
WWise. shackle lift best way to raise rear. Blocks contribute to axle wrap.
