Why is my coilover compressed and bent?
tygr2007
tygr2007
Tyler
Naples, FL
www.tradewindnaples.com
Designer @ Tradewind Designs
Yes, but the cause of it is what you want to fix, right?
If it was a bad install, great, but what about the install was 'bad'. How are they going to make sure it doesn't happen again.
I'd also try and get a better look at the lower spring perch/mount. Take the wheel off of both sides and look at it, is something broken or cross threaded? Is there a pin that's sheared?
Personally I wouldn't drive it until I knew more about what the damage really is. One hard pothole could shear something the whole way through and you're going to slam down and possibly damage more. Or it could just be bent and you can get it to a shop without any major issues, as long as you don't drive it like a racecar.
I can’t upload the video I want, hold on.
Jhbryaniv
2023 Ranger Tremor
NerkyMohawk
Nick
2023 Ford Ranger Tremor Lariat
F&B Manager
What springs did they install? Stock?
So one BDS kit comes with fox 2.5, this looks like the one that dosnt comes with any coilover or spring for the front. Instead it appears they used the tremor fox's
I'd guess. This may have caused issues because the tremors are specifically tuned and not like other stock shocks or the fox 2.0 or 2.5.
Jhbryaniv
2023 Ranger Tremor
Wonder if the fox install has the same snap ring as the install guide describes.
Wonder if the snap ring isn't set in the groove and causing this...
I also wonder, does OP know exactly which kit was installed...
tygr2007
tygr2007
Tyler
Naples, FL
The bds website does not show a spring on the front.
Did you look at the kit before it was installed or do you have a packing list from the order?
BDS1547FS - The one without the Fox 2.5
Talked with BDS R&D and they said that it'd work with the Tremor models.
tygr2007
tygr2007
Tyler
Naples, FL
tygr2007
tygr2007
Tyler
Naples, FL
I have an assumption about what happened and what the problem is.
NerkyMohawk
Nick
F&B Manager
Odd that their website said it dosnt work with the tremor model, but their R&D told you it would be ok.
NerkyMohawk
Nick
F&B Manager
Got it, The facebook tremor group had talked about it as a possible issue when I was looking at leveling options there. They mentioned that the tremor shock is 1 inch longer and the spring is 2 inches longer then vs standard fox.
tygr2007
tygr2007
Tyler
Naples, FL
I’ll put out a whole write up when i’m all done!
Dereku
Derek
Chicagoland Area
2021 Ford Ranger
Project Manager
Remove the 6in lift because it will do nothing but cause issues. Anything over 4ā€ should have solid axles. Just my 2 cents for a happier life with your truck. And spacers can cause these issues too.
I ran 46s in the past so im not anti lift
tygr2007
tygr2007
Tyler
Naples, FL
Lame, and it’s too late. Already cut a bunch of shit.
Rp930
Denver
ā€˜19 Ford Ranger Lariat, ā€˜23 Macan,’21 Shelby GT500
