Buckbull
What mount did you use for the winch?WARN Zeon Platinum 10-S bolted to the frame with 15K lbs. shear bolts. It don’t get any lower profile than this. ARM switch to AUX #4 (5Amp).
CustomWhat mount did you use for the winch?
I guess thats why it looks so good.Custom
universal channel mount for like $50Did you use the channel mount or the fairlead mount?
How did you mount it?universal channel mount for like $50
to the bars.frame that the tow hooks are mounted to. fit right in there. I had to trim a little piece from each end to get it to fit.How did you mount it?
What did you use to trim? Did you use the existing tow hook bolts?to the bars.frame that the tow hooks are mounted to. fit right in there. I had to trim a little piece from each end to get it to fit.
a circular saw. yes, used the existing bolts. there is a thread on facebook that shows it pretty well. it's in the ranger group.What did you use to trim? Did you use the existing tow hook bolts?
