Superdannyboy
- Thread starter
- #1
What's up guys, superdannyboy here.
Looks like Mishimoto recently released an aluminum coolant reservoir in either micro-wrinkle black finish or aluminum finish.
https://www.mishimoto.com/aluminum-expansion-tank-2019-ford-ranger-23l-ecoboost.html
Direct fit for 2019+ Ford Ranger 2.3L EcoBoost
Full-aluminum construction with durable precision TIG-welds
High-visibility sight glass and stamped cold-fill line allow for quick reading of coolant level
Internal baffles keep coolant near overflow port during aggressive driving, preventing air entry into coolant system
Fill neck accepts stock cap for easy maintenance
Available in polished or micro-wrinkle black powder coated finish to suit any style
Mishimoto Lifetime Warranty
DESCRIPTION
It's only been four years since the first Ford Ranger 2.3L EcoBoost rolled off the assembly line, but those four years have been rough on some of the plastic parts under your Ranger's hood. Your coolant expansion tank is probably beginning to show its age thanks to thousands of heating and cooling cycles bathed in orange or pink coolant. It's likely developed that classic dingy yellow tone, and it may be hard to see the coolant level through the side of the tank that gets more opaque by the day. Soon enough, that plastic expansion tank will become brittle, and one misplaced elbow or especially deep pothole has the potential to start a cascade of coolant. Luckily, Mishimoto's 2019+ Ford Ranger all-aluminum expansion tank is built to last a lifetime.
Our Ford Ranger EcoBoost expansion tank is constructed from aircraft-grade aluminum and precision TIG-welded to create a durable expansion tank that can withstand thousands of heat cycles and high pressures without cracks or leaks. On the outside, we've included a high-visibility sight glass and stamped cold-fill line to make checking your coolant level easy, while the available micro-wrinkle black powder coated or polished finishes suit any style. Our fill neck also accepts the stock expansion tank cap to keep maintenance easy. Inside, baffles keep coolant cycling into the engine, no matter how steep the road or trail gets.
Like all of our products, this aluminum expansion tank for your 2019+ Ford Ranger 2.3L EcoBoost is backed by our Mishimoto Lifetime Warranty for a lifetime of durability and worry-free running.
DESCRIPTION
