WeatherTech Side Window Deflector issue.
Grjake
Rusty
Hedgesville, WV
2019 Ford Ranger Lariat
I installed the the In channel side window deflectors on the driver and front passenger window. The windows rubs the deflector when putting the windows up. The passenger window occasionally will not go up completely due to the interference. Anyone else having this issue?
GregP
Greg
Charlotte, NC
Customer Service
I have the same Weathertech deflectors on my windows as well, it definitely did the same thing at first as well. It takes a few weeks and a few warm days in the sunlight but eventually they will go up/down without problem. There is always going to be a minor “bump” sound when the window contacts the deflectors in the channel, but you shouldnt have any problem with the Auto-Up feature.
Peter949
Peter
Irvine, CA
2024 Ranger Raptor
Give it time. It will settle in but at the beginning this will happen.
ChopprJock
Lyn
St. Louis, MO
2019 Ford Ranger Lariat, FX4, Sport, Tow Packages
Aero Engineer / Ops Analyst
I will second what the other posts say...
I installed mine last week as well. At first the windows hit the deflectors pretty hard and that stopped them. I re-read (well...read!) the instructions and it said to give the deflectors a pull (away from the truck) to help seat them in the outer part of the channel. After doing this the windows worked with just a slight rub as they contacted the deflectors.
Less than a week later and now I can't even tell that the window hits the deflector at all...
TremorOwner
2021 Ranger Tremor
In-channel deflectors are known to prematurely wear out the window motors because of the resistance.
Muscleford
George
Ohio north coast
Retired CFO
I had AVS in channel defectors on my 2011 Ranger and never had to replace a window motor in the 10 yrs I owned it. My son has in channel on his 2009 and has never replaced a window motor.
Muscleford
George
Ohio north coast
Retired CFO
Would these in-channel versions damage aftermarket window tint?
I wouldn't think so. Window tint film is on the inside I believe and these would be rubbing the outside.
Markubis
Nashua, NH
Mechanical Engineer
The gaskets for the windows were designed to be tight fitting against the glass.
You're adding extra material for the gasket to seat against now.
As other posters said. Give it time. Warm weather will help, but your best bet is to keep the window in the up position for awhile to pack the gasket.
ChopprJock
Lyn
St. Louis, MO
I have aftermarket tint, no issues whatsoever.
I've also used the same style (Weathertech) guards on many vehicles over the years and have never once had a window drive motor malfunction...
9512tacoma
USA
2020 Ford Ranger XLT FX2
Manager
Did anyone have to install the window channel clip with the front deflector? Was it easy to install the deflector over the top of the clip?
miken
CT
2022 HPR Ranger Lariat, 2021 Mustang Mach-E
The video made it look pretty easy. I chose not to do it at all. It's been a few weeks and I've had zero issues
GreenCreekDucks
Scott
2021 Ford Ranger Tremor
IT Dude
I quit using in channels two vehicles ago... Windows will start to rattle in the track after a few years....
My daughter had these in her Ford Focus. Passenger window burned out a motor because of it “hanging up” on the deflector. I had to remove them and carefully sand the leading edges down to a taper. Took old 3M tape off and put new on. Stopped window hanging up but the last inch of window closing you could hear the motor strain to finish and seat closed.
IdahoRanger
Idaho
2019 Lariat SuperCrew FX4
RETIRED
Didn't use the clips and have no issues.
