TJC
- First Name
- Tony
- Joined
- Aug 28, 2020
- Threads
- 46
- Messages
- 3,978
- Reaction score
- 10,029
- Location
- North Carolina
- Vehicle(s)
- 93 Miata, 05 Ranger 4x4, 20 Ranger 4x4, 23 CX-5
- Thread starter
- #16
I got the odor long before I "cracked open" the can or removed the can to clean it, etc.Tony....when you effectively "crack open" the system you will inherently get a fuel odor with these trucks. Something else...when you folks get cold over in NC you will definitely see a noticeable difference in the amount of vapor you are capturing. At least twice as much when freezing or below. I have a Mishimoto catch can on mine and noticed the odor right away. I don't really get any odor in the cab. Maybe when I open the door but that's it. In the future I would like to have a system that has more capacity to hold the vapor so I don't have to empty as often.
I been doing my own maintenance on my trucks and cars for 40 years. I have repaired my share of oil leaks from all manner of locations. I have removed, rebuilt, and reinstalled engines and transmissions in numerous vehicles. I have supercharged cars and converted supercharged cars to turbocharged cars. I have my own garage out back with a two post hydraulic lift installed in it. In short, I know my way around engines.
I expect the odor of oil when I change the oil or open the catch can.
I do not expect the odor of oil from a closed system. UPR mentioned that you may smell the odor as the vapor moves from the catch can back through the intake track through the air filter box. Theoretically that is possible, but the odor I was smelling was coming from the top of the catch can, not the air intake nozzle on the passenger side of the truck (I have the "dual valve" two hose system).
Take a look at the picture below. Both of these fittings are tight - there is no slop in them.
The left one is factory Ford. The one on the right is the vacuum source for the catch can when the engine is in boost (the Turbo pulls a vacuum on the inlet side when it is in boost) and is part of the UPR kit.
The fittings on the catch can do not seat properly, there is up/down play in them on the can ports, and consequently, they did not seal. And the smell of oil from the can is obviously present on the drivers side of the truck. Both at the tire level and even stronger when the hood is raised and I sniff around the battery and the top of the can. Stronger yet at the fittings.
It is not present any longer as of last night when I added the additional O rings to take up the slack.
Now that I am sure where the problem is, I am going to take a very close look at the plastic locks on those suspect hose fittings. It may be possible that the clips were installed backwards. I have no idea as I have not yet examined them, but I am going to look closely at them today. I never thought to check the the hose fittings as they came custom built. High quality hoses too! I do not know if the fittings are supplied to UPR as a single unit or if they come packaged in pieces and need to be snapped in place when they build the hoses.
All I know is that the odor stopped when I took the slack out of the fittings on the catch can.
The odor in the cab was strongest when air was being drawn from outside the cab and the truck was not moving. All other times it wasn't noticeable.
I will report back on the retaining clips
