k_teven
- First Name
- Steven
- Joined
- Jul 26, 2022
- Threads
- 6
- Messages
- 110
- Reaction score
- 160
- Location
- Bettendorf, IA
- Vehicle(s)
- 2022 Ranger Lariat
- Occupation
- Engineer
- Vehicle Showcase
- 1
Yeah, I believe that. Even if it was their cost, break that down to $50 for each fog and $200 for each headlight. That puts their mark-up for these in the range of 600-900%. That's beyond ridiculous AND ludicrous! More like Effin' OUTRAGEOUS!! And what is even worse....nobody there cares one iota. No explanations, no options, no choices. Take it or leave it.$500 is way more than Ford's part cost...but hell of a lot less than your replacement cost...
The decontented Rangers don't even appeal to me - maybe at $19,995.....Yeah, I believe that. Even if it was their cost, break that down to $50 for each fog and $200 for each headlight. That puts their mark-up for these in the range of 600-900%. That's beyond ridiculous AND ludicrous! More like Effin' OUTRAGEOUS!! And what is even worse....nobody there cares one iota. No explanations, no options, no choices. Take it or leave it.
Here is what the IIHS has to say about the headlights on the New Rangers after doing side by side comparison of the Halogen and the LED headlights. Before I begin here is a little something about the IIHS and HLDI.I am doing the same, waiting to drive quite a bit on dark roads before I pull the trigger, it would be nice if I knew someone around me to do a side-by-side comparison at night.
Not that anyone should be happy about this issue, but also consider that they provided lights. So that cost has to back into the truck, so lower rebate. LED rebate, minus HID provided equipment.$500 is way more than Ford's part cost...but hell of a lot less than your replacement cost...
Considering this was a delete AFTER the order was placed with Ford, there was no option. And look at what other cars that would compare with the Ranger mid-size truck. None really compare, all others are wanna-bes'.Hello. In this situation, ensuring you get what you want isn't easy. Maybe you should take a closer look at other cars?
smells like you're replying to a spambot...Considering this was a delete AFTER the order was placed with Ford, there was no option. And look at what other cars that would compare with the Ranger mid-size truck. None really compare, all others are wanna-bes'.
I think you are right. Multitsking, so did not comprehend everything I read there...smells like you're replying to a spambot...
Wait a minute.Update:
Bought the Factory LED Headlights and Fogs from Ford OEM Parts Direct $2700, got the headlights installed, Fogs are on backorder so they will be installed later.
It took about 5 hours to get them swapped over, HUGE difference over the Halo's.
If you decide to swap yours over as well, just take your time doing it and watch the install video located on this forum. It's really a PITA but worth it. I just wish Ford did not delete them in the first place.
Plus: look in the Forscan WIKI about the changes that have to be made to make them work properly
I posted my install notes in there. as the ForScan changes posted on here are conflicting and not exactly correct as I found
