UCA replace and knuckle question
Jhbryaniv
2023 Ranger Tremor
we’ve called him the lady killer because the nurses in the NICU loved him. This was written on his board.
it is good that he takes after his mom in that department. LOL
Egg69
Erik
Fallbrook, CA
2019 Ranger XLT Sport
Systems Analyst for Bonsall Unified School District
The easiest way to find out is to get a magnet and see it it sticks to the steering knuckle. If it doesn't then it is the early aluminum. If it does stick that. You have the late steel knuckle
Which is better?
Jhbryaniv
2023 Ranger Tremor
Won't matter as it depends on what it was equipped with
It was a year and trim package thing?
I thought it was like tremors got one everyone else got another. Maybe not that specific...
I read about it on here at some point... I think. ?
It was a change during production. I want to say the change started for 2020 model year trucks
Jhbryaniv
2023 Ranger Tremor
Beach
Beach
Multiple
2019 Ranger Lariat, 2016 BMW M235, Volcon Grunt
Financial advisor
wow, pricey!
Ranger_Rocks
Wandering
Wanderer
I just googled it. Lol
Looks like that was the year of change over. Stage motorsports has uca's for 2019-2021 and 2020-2022 listed differently...
https://www.stage3motorsports.com/9...el-knuckle-icon-tubular-delta-joint-ucas.html
https://www.stage3motorsports.com/98510dj-19-21-ranger-icon-tubular-delta-joint-ucas.html
Perhaps cast is post covid plant shutdown. Mine are cast and was built 6/20 shortly after restart.
The easiest way to find out is to look at the color.
Cast=black (+rust), Aluminum=unpainted.
BlacknYellow
Mo
Philippines
2023 Ford Ranger XL
Tech Support
Just gonna piggy back on this. For my 2023 ranger I've upgraded my tires to 285 75 16s and plan on throwing on some 2" leveling strut spacers in a few weeks, in the mean time untill I can afford a proper suspension lift down the road.
I just bought a pair of after market UCAs (2-4" lift) and was wondering if it would be necessary or have any benefits applying an extended ball joint to the UCAs?
pismo1
Temecula,Ca
2020 FX2
Mine was built 03/11/2020 believe it or not(google that date).Mine are aluminum.
Todd Chapin
Todd
Alexandria
2019 crewcab lariat fx4
Chef
Short answer is yes. It will articulate, align and IMHO ride better. You will also be able utilize more travel using extended struts such as the Eibach Pro 2.0 I run with my Icon UCA.
BlacknYellow
Mo
Philippines
2023 Ford Ranger XL
Tech Support
Thanks for your input Todd! I really want to have that leveled look. I know there will be risks to just using strut spacers to level the front. I've read many threads and it seems to be 50/50 in regard to pros and cons. My aim is to avoid as much wear and tear to the other components i.e. cv axles etc. by replacing the ball joint that came with the aftermarket UCA if it would aid any in lessening the potential damage caused by just going with the strut spacer level route.
Todd Chapin
Todd
Alexandria
Chef
Spacers wont cause any harm. I have used them before but glad I did not on my Ranger.
Upgrading your struts with Fox, Bilstien or Eibach will give the lift and a much better control and ride You desire.
Considering it is not a easy task to install the lift or coilovers, particularly on a 4x4 why not bite the bullet and put in the improved suspension you want? You can add UCA later if you still desire or need them.
I did first coilovers, then UCA then tires. I had not really planned on getting Icon UCA until there was a group by on the forum. They do make a diference.
ICE 27
H
Illinois
2021 ranger tremor
Jeff, I’ve had a 2-1/2” level kit and currently have Fox Performance coil overs set at 2”. With both of these setups, there were no issues getting the truck aligned to spec. That seems to be the case with others on the forum as well.
@Colo_Ranger makes a good point about wheel travel when off-roading but keep in mind, he wheels the pants off his rig on a regular basis. So, if this is the kind of driving you have in mind……
….upgrading your UCAs just might be in order.
Love your truck!
