modifying steering knuckle, suspension, and crossmember
V_dude
Sam
Saudi Arabia
Ranger XLT2.2 2022
Hi everyone,
I got access to welding workshop, for those that know my case, I found a way to make some of my US Ranger part to fit on my Austrialian made Ford Ranger, i.e. the rear lift block, I just reduced the size of the pin on top from by 1 mm around and turned it from 14mm to a 12mm and the hole of the bottom just added a 1mm 14OD 12ID pipe. So I am worndering if I can play with some parts. My old man has a broken down SUV that been setting there for more than a year doing nothing which can be my expermental rat.
but before I get started, I got a lot of question, so please excuse me if I am newbie in mechanic, but God bless, the more I learn about the mechanic the more addictive it is getting (I should have went for being a grease monkey after school)
here are the questions:
1- A- Steering knuckle: I know it is attached to lower arm control, upper arm control, and thin shaft in the front of the drive axle (I think it runs to the steering gear) and a rod connected to another shaft behind the drive axle (I think it is steering related as well), and a bunch of holes for wires to run through it, (PX has two holes near the UCA resting hole), the knuckle clearly acts as the wheel turning point and supports the arms which are the bouncing point of the car. if I wanted to turn these knuckles to a lift knuckle, is just making the attaching points for the UCA and LCA go up farther? or is there more to it?
B- if I extend all of fixing points of the steering knuckle to the other components, except for the wheel hub, inwards(make the fixing points extend towards the car) will that make the wheel extend outwards, like the wheel would be more sticking out? (taking into account extending the drive axcle as well)
2-A- Shocks: is it possible to cut off the rod and extend it if I plan to lift the truck (i.e. if I plan to lift 10" I add 10" of rod welding) ? or does the shock needs to be able to be fully compress to the added length? (or close to it) ?
B- can I make some sort of extender?( like making an shock-like eye with two securing points for the factory shock, a home-made shock eye (to attach to the truck) inches away (lift inches) attached to a semi clyndrical channel (that fits the shock width) with a bolt passing through it and a clamp on it, so that the factory shock can rest in channel while the bolt goes through the shock's eye and the clamp further down securing the shock to the extender.
3- A- Coilover, Is it possible to change a coilover ends (securing point), like if I find a coilover of the same width with desired lift but for another type of car, can I change there connections and get away with it? (I am aware that 1" lift for one car doesn't neccessary means the same for another car)
B- Can I add an Extender (mentioned in Question 2-B) to the bottom part of the coilover and use it as a link between the lower control arm and the coilover to push the car upwards?
4- the crossmember, the front one is attached to the lower control arm and support the engine and front car. if I mount it (the factory crossmember) on a home-made crossmember and attach the lower control arm to to the crossmember, will that push the car upwards putting pressure on the coil spring and therefore making the lower control arm pointing downwards toward the wheel side giving it more front ground clearance?
thank you for assisting me
AdamHarris
Adam
Blue Oval City, TN
Collision Repair Instructor
My friend, much respect to you desiring to learn. A forum such as this really is not the place for you to learn about mechanics or automobiles. Entirely TOO MANY folks here who think they know, wish they knew, or desperately want others to think they know automobiles. You seem young and may I suggest you locate an automotive training center of some sort. I have no idea of the post-secondary school opportunities in your area but cars must be repaired and thus there must be a training infrastructure of some sort in place. Get in on that and learn hands on since you have a passion for it and best of luck to you fellow car guy!
V_dude
Sam
Saudi Arabia
Ranger XLT2.2 2022
thank you for the advice, I am really thinking about taking studies in that feild of knowldge.
Hi everyone,
Hi Sam,
There are three systems on a vehicle that you just do not modify without extreme knowledge and skill. Fuel, Brakes and Steering.
Since you are proposing to embark on modifying your truck, you are in dangerous territory to harm yourself and others if there is a failure. You need to stick with proven aftermarket parts for your Ranger, mostly likely from Australia or as we say Rest of the World parts...not USA parts in most cases...
I like your curiosity and desire, so study hard and develop your young hands into experienced and trusted hands..
I am with Phil on this one. As curious as you may be it would be best to stick with the proven products for your truck. It would be different if it had nothing to do with safety. Steering and suspension on the otherhand have too much risk to mess with.
