Turbo low boost pressure
OGMix376
Bryan
Replaced EXHAUST ON MY ECOBOOST 4 CYLINDER.Now setting code PO229
Did you mean Code P0299? Low boost pressure.
Look for air leaks in the intercooler piping… or your wastegate is failing or not fully seating properly in the closed position…
I think one of the biggest things with this is that big soft pipe/tubing on the driver side intercooler plumbing stretching..
hope you get it sorted out brother I’ll be watching because I want to know.
Define - Replaced Exhaust as that may have changed the back pressure in the flow.
TerryW
Terry
mineral, va
2023 Ford Ranger XLT
Interesting. I put a Thermal R&D 3" cat back on mine and did not get a CEL, but the truck feels weaker at lower RPM. I'm going to add the CVF downpipe, CVF charge pipes, CVF intercooler and then get a tune hopefully optimized for new plumbing. I hope the tune restores the low-end pep.
RuggedRanger
A.
2021 Ford Ranger
As said above, check your hoses cause there’s a leak somewhere.
I recently did a big road trip with a heavy trailer after swapping out the air box and retuning my ECU.
For a few hours on the trip while I had the radio off, I said ā€œgee, that new air box sure is loudā€ because the truck otherwise seemed to drive normal but acceleration on highway was terrible. I dismissed it due to the trailer weight. Then the dash started lighting up.
Pulled into gas station, read the codes, saw low/no boost. Said WTF to myself. Inspected boost hoses and found one had popped off. It was laying square against the fitting so didn’t even see it was off until I wiggled it. Screwed it back on. Reset codes. Was fine.
Well, mostly fine šŸ˜†. In my case, with everything I’ve done to my engine, I’m generating a lot of boost pressure way above factory, so the hose kept popping off every few hours until I completely removed it, reseated both sides and cranked down on the clamp. It hasn’t budged in months.
Dr3wDrop
Andrew
OHIO
2021 Lariat Tremor
From what I understand the intercooler is less important. Do you have an aftermarket intake? It shouldn’t fix anything but more of a question.
Mustang2Ranger
Garrett
Southern California
Intercooler makes a heck of a difference preventing heat soak and consistent boost especially when it is hotter out or towing/elevation
The entire ecoboost family of engines is known for becoming heat soaked in more demanding conditions. Normal driving is just fine
6 x Ford
Stretch
UK
2020 Ranger Raptor
What was the verdict? I have the same problem. I have had the silencer removed and 3" cat back pipe put straight through to the side behind the wheel, after a couple of weeks I now have the P0299 Turbocharger/Supercharger 'A' Under boost condition.
Dereku
Derek
Chicagoland Area
2021 Ford Ranger
Project Manager
New exhaust means the turbo can spool up faster and potentially boost higher and faster than the diverter valve can respond. Could have blown a boot off or split one. Look for oil on all the boots. Feel around them. If your hand is oily at all it is leaking there.
