Towing 4 Down
JesseS
Jesse
NorCal (Roseville)
As my MH is combined and the truck is separate I had to get a 2>3 converter to put upstream of the diodes. Cutting and extending the wires in the tail light was simple, just used a meter and straight pin (stick into wire for testing prior to cutting) to ID the correct ones, then route to/from the diodes. I used 3 2 in one out diodes on each side so no relay needed. I am just glad Ford provided plenty of spare room in the tail light housing.
It would have been easier to add stand alone bumper lights but they look like crap, and the rear LED's on the Ranger look cool.
TimmyB
Timothy
Sarasota FL
2021 Ranger Tremor, 2020 Fleetwood Bounder 35P
Have most of you spliced into your Ranger wiring or are you running lights that just attach to the Ranger and have their own wiring?
I am a little hesitant to tie into the factory wiring for fear of voiding the warranty. Any input welcome. Thank you.
Brian
Even though the install of both the Blue Ox baseplate and the Roadmaster wiring kit couldn't look any easier (based on videos on etrailer.com), this was one area I was not going to save a few bucks. If all heck breaks loose (as in, my towing setup fails), I'm not going to stand in front of a judge and say that I THOUGHT I knew what I was doing. I had an authorized Blue Ox dealer (who has done hundreds of these over the past eight years) perform the install. Peace-of-mind for me outweighed a few hundred bucks.
Hi Folks,
I just completed a three week Journey to Flagstaff Arizona and back...Round trip of about 500 miles towing my 2019 Ranger FX4 behind our Diesel Pusher Alfa Motor home...Ranger towed with no real problems until Eloy when I had a fellow flag me on the freeway to a problem. Turned out to be the hookup electrcal loom failed a zip tie (Never use white Zip ties...) and the look was almost ready to abrade on the roadway. So dove off and exit....secured the loom with a bungy cord. So I have towed over 5000 miles with no transmission issues... I follow the owner's manual step by step...I do not rely on my memory. No problems encountered except for this one. If the fellow that was kind enough to motion to me is reading this forum...A big Thank You to you for taking the time to motion to me something was wrong My next move is to a non Zip tie arrangement for the wiring loom...
TimmyB
Timothy
Sarasota FL
Hi Folks,
Hey, Phil.
Glad someone was nice enough to flag you down! We can all hope to be that lucky to have nice people around when things go wrong.
Did you do the "push test" while you were going through the manual or did you trust it when it said "enabled"?
Hey, Phil.
Hi Timmy,
I did the put it in park and it rolled about 1"....Back to neutral and ready to tow. I kept getting the dinging that Neutral Tow was enabled.... Then switched the ignition off...
Here my question to which I do not have an answer, but follow the owner's manual. What is the difference between the trans being in Neutral when the transfer case is in neutral vs the Trans in park? I am guessing the trans freewheels and to a degree lubes the transmission?? Any thoughts on this. I am still puzzled....Wish I could get a hold of Kevin N. who led the design of this trans.... Good guy and a off road racer....
TimmyB
Timothy
Sarasota FL
Hi Timmy,
I would simply be guessing on this. One of the other posters above theorized that (if I'm understanding correctly) if the battery were to die and it would leave neutral tow, the selector being in Park might cause a "bit" of an issue. Of course, that might be the least of our worries, as this is also what might be causing the occasional destroyed transmission for those that have done it correctly but had a failure somewhere.
RoadtripsOfUnusualSize
DFW
www.youtube.com
Formerly owner of an Ingot FX4
Our motorhome is spending the night at a KOA in Amarillo tonight. Pulling in next to me was a very nice couple from Florida in a motorhome pulling a Ranger. We hit it off quickly and shared stories and opinions on the Ranger as a Toad. He was as enthusiastic as I am. Rangers are hard to spot on the road; they're harder to spot behind motorhomes. To have one pull up next to you is unheard of. Cool!
TimmyB
Timothy
Sarasota FL
Well, THAT was an easy conversation starter!
NooTrucker
Hendersonville, NC
2020 Ford Ranger XLT Supercab
Real Estate Appraiser
I've been keeping an eye open since I got my Ranger eight months ago, and have yet to see anyone else towing one behind their motorhome. We're heading out tomorrow for 12 days with the Ranger in tow.
Bsenecal
Brian
Milton Vermont
Military
Enjoy your trip.
Brian
TimmyB
Timothy
Sarasota FL
Everyone of us needs to post a pic of our rigs towing our Rangers so when we pass each other, we'll know who they are! :like:
Hi Folks,
No pix of 2019 Ranger, but here is one with the 2007 Ranger.....
DFW
www.youtube.com
Yesterday in Childress, TX. We stopped for burgers. And, a better shot taken on the Texas coast to show how well the Ranger's Ingot paint matches up with the Bay Star's color scheme.
