- First Name
- Phil
- Joined
- Apr 3, 2019
- Threads
- 149
- Messages
- 7,082
- Reaction score
- 37,218
- Location
- GV Arizona
- Vehicle(s)
- 2019 Ranger FX4 Lariat 4x4, 2020 Lincoln Nautilus, 2005 Alfa Motorhome
- Occupation
- Engineer Retired
- Vehicle Showcase
- 1
- Thread starter
- #61
Hi Dan,I just posted this in towing but since I am new to this forum I am posting here as well - not exactly sure how this forum process works!
Hello fellow Ranger drivers. We just bought a 2018 Minnie Winnie and a new 2019 Ford Ranger 4x4 to tow after ~15 years with a travel trailer towed by an F-250. We are preparing for a 2 week trip from Oklahoma to northwest Colorado in July, and I have several questions and honestly some concerns about flat towing the Ranger.
I have installed the Roadmaster base plate and wiring kit and also purchased the Blue Ox Patriot in-cab brake. Would appreciate your inputs to any or all of my questions, and thank you in advance!
Thanks again!
- I have seen other threads expressing concern over battery drain and resultant potential transmission failure - what is the best method to run a power line from the RV to the Ranger? Understanding you may not have knowledge about my RV, the more specific question is how to hook a power supply to the Ranger?
- On another thread it was stated the in-cab power supply times out - what is the best method to run power to the Patriot brake?
- I was intending to run the brake break-away cable through the engine compartment and the driver's side door to the brake - any concerns with this?
- Is there a problem with driving the truck for some distance just prior to hooking up and towing?
- Is there a recommended maximum speed to tow? I am not intending anything crazy, probably 65mph or maybe 70mph max.
- Does anyone have concerns with towing 500-600 miles+ without unhooking and driving the Ranger?
I tow without a charge line without draining the battery. A charge line can be fabricated quite easily and fuse at both ends. Commercial charge lines are available.
I ran a power line for the Add a Brake from the Ranger's battery through the wiring grommet on the driverside, fused at the battery to avoid the time out of the powerpoints in the Ranger. Tip-Pull a bundle of about 8 wires through the grommet for future use... It is a PITA to run the wires.
My brake-away module is at the front of the vehicle and the the wiring runs through the same grommet..
Should be no problem with driving the Ranger just prior to hooking up. Here is something I do...I leave a good distance from the RV with the tow bar. Then I set the parking brake and go through the process to put the Ranger in neutral tow mode with the transfer case in neutral. I then release the parking brake and then by hand push the Ranger forward. It should roll forward a foot or two freely...If it does not roll...repeat the neutral tow function.
We tow up to 70mph but I keep most times to 65mph or lower.
Towing 500 to 600 miles should not hurt the Ranger at all.
Hope this helps.
