- Thread starter
- #1
I'm pretty impressed that a Ranger can tow up to 7,500 lbs. However, I mostly want the Ranger for off-road use so I'm wondering if adding the option trailer hitch will reduce the departure angle for the Ranger?
Yes, slightly.
I'm no expert, but I believe it is due to the tow package sticking out below/back of the bumper:Trying to understand this ... is this because of the added weight or because the hitch is closer to the ground? Or both?
Your read my mind about how many degrees were lost with the towing hitch, thanks!It takes away about 2 degrees. So yeah, not a big issue, well, for me anyway, and i would rather scrape the hitch than the bumper, provides a recovery point, and if its really that much of an issue. 2 c clamps and a 21mm socket help take of 4 bolts, remove the hitch, put the bolts back on so you dont lose the bumper
I would get a Bronco, or a Wrangler, but I kind of need the payload and sometimes the towing capacity of the Ranger.I guess Carl needs to make a decision on whats more important....towing, or radical offroading.
Maybe Carl needs a Bronco for the offroading.
Pony up Carl, get out the checkbook.
You have to compromise somewhere.......
I totally agree, and I find all the serious 4x4 guys in Australia also run hitches and promote them as something you want on your offroader to protect the underside of your vehicle.Personally... If I'm going to bottom out, I'd rather hit on the hitch than the bumper itself.
I heard that you shouldn't use lift kits that use block lifts if you're planning on rock crawling or some other type of very demanding off roading. Is there any truth to this?Lift kit will also fix the decrease from the hitch and even gain some over stock if you go big.
I would not. Many lifted leaf spring choices available. Old Man Emu comes to mind.I heard that you shouldn't use lift kits that use block lifts if you're planning on rock crawling or some other type of very demanding off roading. Is there any truch to this?
I have read this as well. You're probably best off getting taller tires and lifting the front a bit to get you going.I heard that you shouldn't use lift kits that use block lifts if you're planning on rock crawling or some other type of very demanding off roading. Is there any truch to this?
