To tune or not to tune
PltFX4
Richard
Minneapolis, MN
2019 Ranger Lariat FX4
A tune is not normally the first thing you do to a bone stock vehicle; usually you remove restrictions on the intake and exhaust first. I plan on a high flow cat as the first bolt on.
Modern OEM cats seem to cost most engines just 3 hp... for the cost of a new downpipe with high flow cat, IMO, not worth the trouble. Maybe when the OEM cat clogs up or rusts out and needs replacing, OK.
We Have Proof: Catalytic Converters Do Not Rob Horsepower
NerkyMohawk
Nick
2023 Ford Ranger Tremor Lariat
F&B Manager
Actually I just doubled checked the CARB exemption. It states the Ford Performance only markets the tune and box.
bmidd
Chattanooga
2020 Explorer ST 2019 Suburban
Worker Bee
If you're spending the money, spend it on something other than a Ford tune.
Justamessenger
Neal
North Texas
2023 Ranger SuperCab HPR Lariat FX4 Tech
Financial Services
But they didn’t compare the 2.3 EB cat with any of the available 3” mandrel bent cats. The Ford part is a restriction in the otherwise 2.5” exhaust, it isn’t mandrel bent so it might be 2” at the narrow passages. Just look at the comparison on any install video.
NerkyMohawk
Nick
F&B Manager
Pretty sure remember the performance facebook group mentioning the 3 inch downpipe with a full 3 inch exhaust is good for about 10 to 15 more HP. With both you'd be spending at least the same amount as a tune. While any tune would give you considerable more.
I have a bunch of bolt ons except for injectors and a bigger turbo and by far the biggest improvement was just a tune. Pretty sure that is for all ecoboost engines.
Remember that if you only focus on Horsepower, you will be disappointed all the time. You also have Torque to consider along with the fact the entire Power Band and not just the peak power point.
NerkyMohawk
Nick
F&B Manager
I agree, but a tune impacts both of those as well. A tune gives about 100 torque, a downpipe wont give that. Now that downpipe will defiently help open up the low end and high end of the power curve. Does not change that bang for buck a tune is the best for improving the ecoboost. Then that tune is only going to help increase the improvements of all the bolt ons.
That applies for any Engine, not just the Ecoboost.
Burnt Money
Andy
Charleston SC
2020 Ranger XLT FX4
I’ve been running the Livernois tune for 80k miles with zero issues. My favorite is the 93 performance. I run the tow/haul tune most of the time due to towing so often. My opinion from everything I have read on this forum over the years is Livernois and Unleashed would be my pick. I’m sure there are probably other great tunes available. These 2 seem to be the most popular and everyone likes the results and the support from both from what I can tell.
jflogerzi
Moreno Valley, CA
Honestly its not worth it. I run the Livernois tow haul tune because I tow alot 5000 LBS... not sure I can tell the difference. Try driving in tow hual mode with stock tune and 93 octane
Keep in mind that the Tune alone changes the Torque Curve a bit and it is still best to use Tow Haul Mode both Stock and Tuned while Towing.
PltFX4
Richard
Minneapolis, MN
I know it's splitting hairs, but we were talking cat... stock vs high flow... not a bigger downpipe, etc. The point was that cat is NOT the power stealer it's made out to be. I'm sure the bigger pipe, mandrel bending, etc. WILL make a good bit of difference (it does on one of my cars). But cat alone, not so much.
DranC
Drandon
Florida USA
2023 Ford Ranger XLT SuperCab
Healthcare Corp Analyst
I had the FPT done also and really liked it. But the very best thing I did was install Banks PedalMonster!. This device is customizable and removes every pause/lag from the accelerator to the PCM. My truck will shit-n-git now buddy!
