This is a first for me!
Sarge104
Perry
Montana
www.facebook.com
19 FR, 13 VB, 95 GS MH, 00 HE
County Cemetery District, SAR volunteer
If all else fails call the local fire department, I bet they will use the "jaws of life" and cut open a hole for you. Probably for free!
On a serious note I hope its something as simple as reattaching a wire end.
ryyck
ryyck
Charlotte NC
its been quite awhile...whats the verdict?
My appointment is for Thursday morning. But I wanted to try and open the hood when it cooled down (just got back from Atlanta). I tried this morning and it opened right up. I'm going to lubricate the latch and watch it. Kind of crazy...but I'd rather use grease then go to Ford. If it fails again, I'll do the same thing. Then, when I have to take it in for service, I'll let the experts take a look.
Thanks everybody.
ryyck
ryyck
Charlotte NC
One benefit from Ford not doing their job with the pre-delivery checklist was that the washer fluid tank was empty to begin with. Since I had to fill it, I ran into the hood latch problem. Maybe, this will save me from having a worse problem down the road - since I got to lubricate a hood latch. The air in the tires was 45 pounds, no washer fluid, rear diff low,.....I'm learning.
Hi ryyck,
Dealer responsibility, not Ford. Not sure why you had no washer fluid from the factory. It comes into the plant in huge tanker trucks and every truck is to be filled with a measured amount. It is not filled up but here is fluid there....Wonder why yours was dry....Are you sure there wasn't any fluid in the bottle...maybe you just could not see it?
ryyck
ryyck
Charlotte NC
Hi ryyck,
Hey Phil,
We had a little...about a short squirt...then the error code showed up. Which was fine...it made me try to fill it. That's when the hood release didn't work. I tried it this morning, and it released. I put a little spray lubricant on the spring and catch - seems ok now. I have no idea why it didn't release. I've done it a few times in the past. We even changed the oil about a month ago - no problem. We have a full gallon of washer fluid now. I'm going to keep an eye on it. Thanks for the info.
jsphlynch
2019 Ford Ranger XL
My washer fluid tank was almost empty when I drove off the lot. In the end I decided that was a good thing as the factory washer fluid did not seem very effective, so I was able to fill the tank with some stuff I know works well for me.
Rear diff was low? I never even thought to check that.
ryyck
ryyck
Charlotte NC
From what I understand, it doesn't top off...just kind of slooshes around. But it should have a decent amount. We checked it out just out of curiosity.
BannonJr
BANNON
Hudson Quebec Canada
2020 Ranger
Locomotive Attendant
When I got mine home I had a bug deflector to install. Took me a solid 20min to get it open. Ended up having a neighbor push n pull up on the hood while I messed with the handle pull in the cab.
It finally popped and havent had a problem since.
I thought I was losing my mind...I was a race mechanic for 20 years lol and cant open a dang hood!
Not sure what hood deflector you put on but did you need to adjust the hood latch up a little to get the hood to close easier. I had to do that when I put on my AVS Bugdeflector II. Haven't had any issues with the hood not opening yet, but will watch for it and keep it lubed.
BannonJr
BANNON
2020 Ranger
Ya the AVS... have to slam the hood a bit harder lol but...dont open the hood that much. If it becomes an issue I'll raise the latch
ryyck
ryyck
Charlotte NC
I lubricated the spring and latch...so far I'm good. I put in the Roush CAI and added lots of washer fluid.
TomSim
tom
toronto
It's not operator error. I have been releasing hoods for 50 years. I know how to do it. The hood will not release when I use the latches. I was hoping there was a way I can reach the latch without the usual pull cable.
Does it feel like theres tension when you activate the dash release, if so, tap the hood in the milddle of the hood with your fist, or have a person pull and hold the dash latch and try fisting the hood
