Tailgate step?
Radioman
Kent
Roseville, CA
To those of you installing one of these steps...please report back after using them during the winter when they are full of snow, ice and mud.
The Ranger will never see snow, ice, or mud... The Jeep, sure, but the Ranger, never. :LOL:
Gazmic
WA
Machinist
Just installed mine last weekend. It is a bit pricey, but worth every penny!! took about an hour. Must have if you climb up in your bed frequently and am a short person like me. :LOL:
Sandman Ranger
Pete
Lead Process Engineer
Although I really would like a step, I'm reluctant to make the purchase because of winter issues. The OEM Ford step on the F150 in front of the rear wheel is a royal PITA in the winter and rarely work like they are suppose to., even when well oiled. These are in the direct path of debris kicked up by the rear tire.
Those who live in heavy snow country know that in super cold heavy snow not much works as normal. Yes they are in a path behind the wheels so could be impacted. Mud flaps will help. Keeping clean and lubed will help. But to expect anything that moves to work as normal under 10F is asking a lot.
rdgallo
Ron
Morton, Illinois
2020 Ranger Lariat Crew Cab 4X4
Retired Caterpillar, Inc. Senior Quality Engineer
I can relate to the short person problem. I am only about 5'3" and have the added problem of operating with two hip replacements and a knee replacement. When you use this step, do you step from it to the top of the bumper to get into the bed or do you go from the step right to the bed? I am trying to decide if this will work for me.
Thanks in advance!
Pvsaint
Tucson, AZ
2019 Ford Ranger - 2014 Tiffin Phaeton Motorhome
Retired Fire Captain
Here's a YouTube video showing its' use. About the 2:40 mark he finally uses it.
TrekStep use
I received my step a couple days ago but with temps around 105 degrees here in Tucson I'll wait til it cools down to install it.
TrekStep use
Hi Paul,
20 miles south, we hit 110° in Green Valley.....
Gazmic
WA
Machinist
Thanks in advance!
I go from the step right to the tailgate / bed. Wish I lived closer so you could give it a once over.
JoeC
New England
A question for those folks that have installed this Bestop step...
Did you wind up using any of the supplied spacers, for height?
(I haven't received mine yet, just reading the instructions, collecting tools, etc.)
Sandman Ranger
Pete
I did not use any.
Good because it is a lot of work to unbolt and add a shim.
Took a chance as I wanted it to fit tight. No shim works.
In relaxed position it is 8-10mm from bumper. If I lift it as much as possible I does not touch bumper and is about 2-3mm from it.
Wanted to make sure it would not bounce and hit bumper, chipping paint. Mine is adjusted all the way to right in picture. I lined it up with bumper. Can move to left 1-1.5" if one wants more step when tailgate down.
JoeC
New England
I did not use any.
Thanks a lot Sandman, that's what I was wondering about.
Looking at the instructions, I'd have to take it down and start all over again to add a shim!
I appreciate the input.
Sandman Ranger
Pete
No problem.
Luckily I did not have to pull back down. Hope it works out.
Rinn69
N. Central Iowa
Retired USAF MSgt
I did not use any.
If it were mine, I'd feel a little better by adding a couple of those clear rubber bumpers to the bumper where it might contact. You can find them at any Lowes, Home Depot, etc.
Sandman Ranger
Pete
Agree with suggestion.
But even if I lift the step with force it does not touch. But, protection never hurts.
r1ch999999
Rich
Nashua, NH
Software Engineer
that seems so expensive to me
