The loose wire inputs are red for brake lights, green for right turn, yellow for right turn, brown for tailights and white for ground. There is also a black for 12 VDC from the battery. Wonder how he hooked that up. The module uses the 12 VDC to supply the output power, so there is no additional load on the inputs. That's how it isolates the input from the output. Since the module he called out was a 3 wire to 2 wire converter, and it's specs say it can't be used on a 2 wire input, where he was getting a 3 wire input, if he wasn't splicing into the tailights.You are correct on specifics - yes, the prewired 4-Pin is the Lightbar
I understand using the T-harness to get the reverse lights from the 7 pin truck harness without tapping into the OEM harness. This makes sense.
I understand the need for the Teknosha module, Just too many questions about how the it is tied in.
What I don't understand is the OPs reluctance to provide us a simple diagram, or simply ask for some time to provide one. The somewhat rude answers I received baffled me, when he originally posted that he had a solution to a problem that has baffled many people trying to hook up tailgate bars.
