- Joined
- Aug 24, 2022
- Threads
- 28
- Messages
- 4,534
- Reaction score
- 8,634
- Location
- Midwest - KS
- Vehicle(s)
- 2022 Ranger Lariat-Super Crew, Cactus Gray
- Occupation
- Aircraft Tech
To get a true reading - you have to manually push the hood latch down (2-Detents)19 Ranger XLT, I am currently on my 4th battery since new! First two were covered under warranty, I have replaced the third and now 4th. Third one was done at Ford dealership where I go, 4th I did because of being a weekend and needing the truck. We had been on a 3 week road trip in a rented RV, going into week 2 to 3 on the road I decided to check my Ford app to see what was going on, mainly curiosity but also I was concerned because of battery failures in the past. App said truck had gone to sleep to preserve battery. At that point I knew I should have disconnected the negative cable before leaving...lesson learned. When we returned I was going to pull the truck out so we could unload the RV, truck was so freaking dead it had nothing, was able to grab my volt meter and it showed 3 volts across the terminals! I think this qualifies as dead. Battery was purchased in January 2025, basically new. Meanwhile my wife goes to her Tacoma parked next to mine and it starts right up...yup I was butt hurt. Threw on the charger for an overnighter. Next morning, nope dead, battery would not recover. Battery replaced under warranty, attempted to acquire a parasitic draw, but not sure if I had the hood completely closed. I had locked the car so it would go to sleep, came back an hour later for a reading, it was showing a draw of .14 ma. Should be .05ma if Im right.
Truck has 77K, have had no other issues except the battery. On extended warranty so I'm going to have to take it in. What I hate about that is if Ford finds no issues I have to pay 200 for diag. If they do find an issue and it's covered I'll pay 100....ugh either way...
1st detent = popped open and under hood release holding the hood
2nd detent = fully closed - This closes the Hood Ajar Switch
To Reset it- Pull The Hood Release Handle in the cab and it will release back open.
I will say though that something is off, be it parasitic draw or with the charging system including the BMS sensor itself.
Even at 3-weeks it should not be anywhere near 3-volts on the battery, so either a high draw or the battery is not being charged properly.
Definitely needs a deep T-Shoot for this:
Questions
1. How often do you hear the Wastegate Actuator cycle when the truck is parked?
2. When you open the drivers door after it has been parked, do you hear it cycle?
I am looking for (Wake Circuit) powering down? completely or is the TCU excessively waking the circuit by constantly checking in on (health)
Even with that - Deep Sleep Message and Action - Comes in play @ about 11.5 Volts, so if operating properly all but bare minimum modules should completely shut down and the TCU becomes disabled.
So something else is pulling power I think - outside of the modules control- possible extra aftermarket add on's Lighting, Winch ,Camera etc.
Have you ever monitored charging voltage while driving - plug in voltmeter (in the PowerPoint)?
This would show if the charging system is operating within normal for the Ranger.
So it needs to be T-Shot down to - System undercharging the battery and its consistently killing the battery cells or an actual unwanted draw
