Sync 3 v3.3 Update Available - 4U5T-14G381-AN
DentonB
Denton
Tulsa OK USA
2019 Ranger Lariat FX4, 2019 Ram 4x4 Cummins), 2015 Audi A3 convertible
Latest is 3.3 Build 19052
Didn’t fix my CarPlay microphone issue either.
Geoff
NYS
'19 Ranger 1943 Willys Jeep
Retired Engineer
Geoff
NYS
Retired Engineer
Yeah..my Wi-Fi in the garage is good, but I can't get it to work for the update. I have 3.3 installed since the factory. Might try the thumb drive route. If I am successful, I will report back.
Yeah, my garage WI-Fi has good signal strength and my iPhone and Macs have no issue but the truck does.
MT19RANGER
JERRY
SIDNEY, MT
Geoff
NYS
Retired Engineer
Yes, Bingo!
I ended up using an XQD Card (they're used for cameras) and it worked. I used Windows 7 to setup the card.
The update responses from Sync were a bit different than the instructions but it completed and I now have build 19052 installed and running fine (KOW).
I did perform a master reset prior to the XQD Card update but I don't think it had anything to do with it finally working. On the Other Hand, my Sirius subscriptions are now all avallable - prior to the Master Reset, weather info was "not available".
EDIT: For you Mac users - In reviewing what I did I think I may have discovered why my earlier update attempts failed. When I formatted the flash drives on my MacBook I used Disc Utility and it defaulted to GUID Partition when I chose ExFat formatting. I'm thinking I should have chosen Master Boot Record instead of GUID Partition prior to formatting.
j0shm1lls
j0shm1lls
Josh
SoCal, USA
www.youtube.com
2016 Focus RS, 2019 Ranger SCrew Lariat FX4 Sport
Done! Looks like the "network connection needed" bug was squashed!
coblueberryranger
Jesse
Tulsa, OK
2019 Ford Ranger XLT
IT Consultant
Just got mine done with USB. Seemed a little strange it worked so quickly (5-10 minutes - no key cycling or anything as described on ford site) but definitely shows the same build number as you guys are seeing! And extremely noticeable touch screen speed improvements and loading times!
coblueberryranger
Jesse
Tulsa, OK
IT Consultant
Did anyone see this file on their usb and upload to the ford site? I didn't so not sure what happened with my update lol even tho it seemed to update as I noted above this post
by showing the correct build version
rangerdanger
SF Bay Area
Yes you upload it to the Ford Owner's site to confirm that you successfully installed the update. That way Ford knows what version you are currently running.
coblueberryranger
Jesse
Tulsa, OK
IT Consultant
Yeah but the XML file never came back onto my USB is what I'm saying so it seemed like it didn't update. Anyways I just spoke with Ford Sync Support and he said this
To clear this up, this is normal, SYNC 3 updates actually no longer use the XML file to report. To report the update, just connect the vehicle to Wi-Fi in Settings > Wi-Fi, then enable automatic updates in Settings > General > Automatic System Updates. This should push the update to us automatically.
So if you updated usb and do not see the xml file on your usb when you plug it in to your computer again, not to worry about reporting the update!
rangerdanger
SF Bay Area
I have Wi-Fi turned off in my Ranger and have not attempted to update via Wi-Fi. That could be why I get an XML and others don't.
coblueberryranger
Jesse
Tulsa, OK
IT Consultant
I didn't update the system via wifi, I did it via the usb. It updated and then when trying to upload the xml file to the website it did not exist on my usb. So they told me this can be expected and that the update will go over wifi. It must just be a thing where the system detects I turned on wifi after the update and will report that way instead.
rangerdanger
SF Bay Area
When I opened the XML file it has a bunch of diagnostic data. Nothing super special.
